I am doing a school project. I want to count the number of drops dripping from the intravenous bottle which are used in hospitals. I have tried using laser emit and LDR sensor. I have tried passing the drops between the laser emit and LDR sensor placed in line. But I drops were not detected. Can anyone give me another alternative for my project.
LDRs are very slow to respond to changes so that may be why it did not work. An IR photo-transistor is many times faster than an LDR and may detect the drops.
I would think that a nice bright IR LED would work, but I don't know your setup so no guarantees. I would be very wary of using an IR laser except where it can be totally enclosed so that there is no danger to anyone.
You will need to test the IV tubes to see if they will pass IR light. Remember the light will have to pass through two thicknesses of plastic as well as being diffused by the liquid.
The reference in reply#1 shows transmitted and reflective modes of operation. You may want to experiment to see which gives the best response to the drop.
Unless you enclose the drip chamber in a lightproof box, which is not really appropriate as the drips must be visible to others, you need to use modulated light - whether it is visible or infra-red - so that the sensor does not respond to illumination by ambient light.
The second problem is alignment. You may need to allow for the drip chamber not to be precisely vertical so the drops do not fall down the centre. Also, a drop is of course, transparent, and as it obstructs the light beam, it does not do so completely, so you are looking for a decrease in the light but not complete blocking. An interesting alternative is to detect scatter instead - have a black pad opposite the light source whether laser or not, and sense perpendicularly to the beam. Again, modulated.
You may not realise this, but while optical drip sensors were used at one time for this purpose, they proved to be quite unreliable and have therefor been completely replaced by peristaltic pumps.
Banana bag, bright yellow and full of all manner of goodness. My son has had near-miraculous recoveries with call outs to collapsed patients who looked at death's door and then walked off like Lazarus after a bag full.
Back in August 94 I published a circuit to count and time drips in order to show the emergence of chaotic behavior as the drip rate increased. I made this circuit.
groundFungus:
Grumpy_Mike:
Paul_KD7HB:
