HI all, long time lurker first time poster : and I have a couple questions nagging me about buffer chips
first one 74HC244 vs 74HC245, I know the 244 is inverting, and the 245 is not, but its their descriptions that has me wondering "what else is different"
74HC244; 74HCT244 Octal buffer/line driver; 3-state
74HC245; 74HCT245 Octal bus transceiver; 3-state
so what is the difference tween a buffer and a transceiver, cause the 245 is often suggested as a buffer
Question 2
While piddle farting around with a memory stick pro I needed to lower the 5v arduino levels to 3v, some random thread on some random website stated "oh just use a 74HC244 or 245, run 3v into its power connection and it will shift levels tween 5 and 3v for you"
now I instantly said hogwash but hooked it up anyway, and yea what happens is the chip is passing 5v from the arduino side to the suposedly 3v outputs at 4.8 or so volts, so ...
Question 2a) what is the point of the buffer if its electrically connected enough to pass voltage from a digital output to the buffer output
2b) if I was mistaken and somehow the above does work as a level shifter, does anyone have a clue on how to do it, cause apparently I dont
thanks
