The sketch that I have been given has about 12 .cpp files and an equal number of .h files.
I’m trying to make this beast work, and, I have a need to dive into the .cpp files and try and see what’s going on.
I have looked at a few of them as well as did some research on them but there are a few things that are not explained.
The guy that wrote my sketch did not seem to have any organization in mind as he wrote them.
So, on to my questions.
- Are the cpp files resident at execution time
- There seem to be multiple sub-routines (?) within a .cpp file and they seem to be invoked as somecpp::sub-routinea.
Is this proper code ? - Is it proper and/or good technique to call another .cpp::routine from within a .cpp ?
In the 2nd example, I have highlighted where I think another .cpp is called from within. - For those .cpp files that contain multiple sub-routines, what indicates the end of the sub-routine ? It looks like it might be }}}}}
Here are some examples:
Main program. .ino
/* Autonomous Satellite Tracker.
* Connections on Adafruit ESP8266 Huzzah:
* Servo controller connects to SDA and SCL
* GPS TX connects to 16, RX to 2
#include "AutoSatTracker-ESP.h"
#include "NV.h"
#include "Sensor.h"
#include "Circum.h"
#include "Gimbal.h"
#include "Target.h"
#include "Webpage.h"
NV *nv;
Sensor *sensor;
Circum *circum;
Gimbal *gimbal;
Target *target;
Webpage *webpage;
/* called first and once
void
setup()
// init serial monitor
Serial.begin (115200);
// this just resets the soft timeout, the hard timeout is still 6 seconds
ESP.wdtDisable();
// scan for I2C devices
resetWatchdog();
Serial.print (F("Scanning I2C:"));
for (uint8_t a = 1; a < 127; a++) {
Wire.beginTransmission(a);
if (Wire.endTransmission() == 0) {
Serial.print (' '); Serial.print (a, HEX);
// instantiate each module
Serial.println (F("making NV"));
nv = new NV();
Serial.println (F("making Sensor"));
sensor = new Sensor();
Serial.println (F("making Circum"));
circum = new Circum();
Serial.println (F("making Gimbal"));
gimbal = new Gimbal();
Serial.println (F("making Target"));
target = new Target();
Serial.println (F("making Webpage"));
webpage = new Webpage();
// all set to go.. see you in loop()
Serial.println (F("Ready"));
/* called repeatedly forever
void
loop()
// check for ethernet activity
webpage->checkEthernet();
// check for new GPS info
circum->checkGPS();
// follow the target
target->track();
void
resetWatchdog()
ESP.wdtFeed();
yield();
and here is one .cpp, the smallest
/* this class contains information about the 9 dof spatial sensor
#include "Sensor.h"
/* class constructor
Sensor::Sensor()
// instantiate, discover and initialize
resetWatchdog();
bno = new Adafruit_BNO055(-1, BNO055_I2CADDR);
resetWatchdog();
the next statement illustrates what is my question. Adafruit_BNO055::OPERATION_MODE_NDOF
is located somewhere else, in another .cpp file ?
sensor_found = bno->begin(Adafruit_BNO055::OPERATION_MODE_NDOF);
if (sensor_found)
Serial.println (F("Sensor found ok"));
Serial.println (F("Sensor not found"));
installCalibration();
/* read the current temperature, in degrees C
int8_t Sensor::getTempC()
if (sensor_found)
return bno->getTemp();
return (-1);
/* return whether sensor is connected and calibrated
bool Sensor::calibrated(uint8_t& sys, uint8_t& gyro, uint8_t& accel, uint8_t& mag)
if (!sensor_found)
return (false);
sys = 0;
gyro = 0;
accel = 0;
mag = 0;;
bno->getCalibration(&sys, &gyro, &accel, &mag);
return (sys >= 1 && gyro >= 1 && accel >= 1 && mag >= 1);
/* read the current az and el, corrected for mag decl but not necessarily calibrated.
* N.B. we assume this will only be called if we know the sensor is connected.
* N.B. Adafruit board:
* the short dimension is parallel to the antenna boom,
* the populated side of the board faces upwards and
* the side with the control signals (SDA, SCL etc) points in the rear direction of the antenna pattern.
* Note that az/el is a left-hand coordinate system.
void Sensor::getAzEl (float *azp, float *elp)
Wire.setClockStretchLimit(2000);
imu::Vector<3> euler = bno->getVector(Adafruit_BNO055::VECTOR_EULER);
*azp = myfmod (euler.x() + circum->magdeclination + 540, 360);
*elp = euler.z();
/* process name = value pair
* return whether we recognize it
bool Sensor::overrideValue (char *name, char *value)
if (!strcmp (name, "SS_Save")) {
saveCalibration();
webpage->setUserMessage (F("Sensor calibrations saved to EEPROM+"));
return (true);
return (false);
/* send latest values to web page
* N.B. labels must match ids in wab page
void Sensor::sendNewValues (WiFiClient client)
if (!sensor_found) {
client.println (F("SS_Status=Not found!"));
client.println (F("SS_Save=false"));
return;
float az, el;
getAzEl (&az, &el);
client.print (F("SS_Az=")); client.println (az);
client.print (F("SS_El=")); client.println (el);
uint8_t sys, gyro, accel, mag;
bool calok = calibrated (sys, gyro, accel, mag);
if (calok)
client.println (F("SS_Status=Ok+"));
client.println (F("SS_Status=Uncalibrated!"));
client.print (F("SS_SStatus=")); client.println (sys);
client.print (F("SS_GStatus=")); client.println (gyro);
client.print (F("SS_MStatus=")); client.println (mag);
client.print (F("SS_AStatus=")); client.println (accel);
client.print (F("SS_Save="));
if (calok && sys == 3 && gyro == 3 && accel == 3 && mag == 3)
client.println (F("true"));
client.println (F("false"));
client.print (F("SS_Temp="));
client.println (getTempC());
/* read the sensor calibration values and save into EEPROM.
* Wanted to stick with stock Adafruit lib so pulled from
* post by protonstorm at https://forums.adafruit.com/viewtopic.php?f=19&t=75497
void Sensor::saveCalibration()
// put into config mode
bno->setMode (Adafruit_BNO055::OPERATION_MODE_CONFIG);
delay(25);
// request all bytes starting with the ACCEL
byte nbytes = (byte)sizeof(nv->BNO055cal);
Wire.beginTransmission((uint8_t)BNO055_I2CADDR);
Wire.write((uint8_t)(Adafruit_BNO055::ACCEL_OFFSET_X_LSB_ADDR));
Wire.endTransmission();
Wire.requestFrom((uint8_t)BNO055_I2CADDR, nbytes);
// wait for all 22 bytes to be available
while (Wire.available() < nbytes);
// copy to NV
Serial.println (F("Saving sensor values"));
for (uint8_t i = 0; i < nbytes; i++) {
nv->BNO055cal[i] = Wire.read();
Serial.println (nv->BNO055cal[i]);
// restore NDOF mode
bno->setMode (Adafruit_BNO055::OPERATION_MODE_NDOF);
delay(25);
// save in EEPROM
nv->put();
/* install previously stored calibration data from EEPROM if it looks valid.
void Sensor::installCalibration()
resetWatchdog();
// read from EEPROM, qualify
nv->get();
uint8_t i;
for(i = 0; i < nbytes; i++) {
if (nv->BNO055cal[i] != 0)
if (i == nbytes)
return; // all zeros can't be valid
delay(25);
// set from NV
// Serial.println (F("Restoring sensor values"));
for(uint8_t i = 0; i < nbytes; i++) {
Wire.write((Adafruit_BNO055::adafruit_bno055_reg_t)
((uint8_t)(Adafruit_BNO055::ACCEL_OFFSET_X_LSB_ADDR)+i));
Wire.write(nv->BNO055cal[i]);
// Serial.println (nv->BNO055cal[i]);
delay(25);
