First time posting. I am trying to write two number characters and one letter on a seven segment display.
I found out about sprintf() and it worked just fine. Until I wrote a loop that handles floats and moves the decimal point. The function is set up to receive a float and a letter and it will write (number)(number)(letter) to the display with the decimal point somewhere to show what you're looking at.
The function works fine and all but when I put it twice in the code, it crashes upon getting to that part of the code.
I have a button that cycles through the modes and switch case that reacts to the modes.
I have no idea what is wrong and why I can't get it to work. I am completely lost now. I tried clearing the SRAM right after but that doesn't help either.
It seens like whenever there are few more sprintf() things, the Arduino dies.
Here is the whole code:
#include <SevSeg.h> //https://github.com/DeanIsMe/SevSeg
#include <FastLED.h> //https://github.com/FastLED/FastLED
#define SelectButton 2
#define DispB 3
#define LEDData 4
#define Dig3 5
#define Dig2 6
#define DispG 7
#define DispC 8
#define DispF 9
#define DispDP 12
#define PlayPauseButton 13
#define DispD 14
#define DispE 15
#define DispA 16
#define Dig1 17
#define CurrentPot 21
#define VoltagePot 20
bool buttonsPrev[3];
uint8_t dispMode;
float setCurrent;
float setVoltage;
float realCurrent = 6.9;
float realVoltage = 42;
float timeHours = 0.75;
float timeMinutes = 45;
float realTemperature = 35.5;
#define NUM_LEDS 2
CRGB leds[NUM_LEDS];
SevSeg sevseg;
//CLEAR-MEMORY-WHAT-AM-I-DOING-IDK!!!--begin
#ifdef __arm__
// should use uinstd.h to define sbrk but Due causes a conflict
extern "C" char* sbrk(int incr);
#else // __ARM__
extern char *__brkval;
#endif // __arm__
int freeMemory() {
char top;
#ifdef __arm__
return &top - reinterpret_cast<char*>(sbrk(0));
#elif defined(CORE_TEENSY) || (ARDUINO > 103 && ARDUINO != 151)
return &top - __brkval;
#else // __arm__
return __brkval ? &top - __brkval : &top - __malloc_heap_start;
#endif // __arm__
//CLEAR-MEMORY-WHAT-AM-I-DOING-IDK!!!--end
FastLED.addLeds<WS2812B, LEDData, GRB>(leds, NUM_LEDS);
FastLED.setBrightness(10);
byte numDigits = 3;
byte digitPins[] = {Dig1, Dig2, Dig3};
byte segmentPins[] = {DispA, DispB, DispC, DispD, DispE, DispF, DispG, DispDP};
sevseg.begin(COMMON_ANODE, numDigits, digitPins, segmentPins, false, false, false, false);
sevseg.setBrightness(10);
pinMode(SelectButton, INPUT_PULLUP);
pinMode(PlayPauseButton, INPUT_PULLUP);
void displayNumberLetter(float number, char letter) {
char buf[4];
if (number < 1) sprintf(buf, "%d%c",(int)(number * 100.0) % 100, letter); // combining the number and the letter (it cant handle floats so I have to separate them)
else if (number < 10) sprintf(buf, "%d.%d%c", (int) number, (int)(number * 10.0) % 10, letter); // combining the number and the letter (it cant handle floats so I have to separate them)
else if (number >= 10) sprintf(buf, "%d.%c", (int) number, letter);
//nwm this doesnt help freeMemory();//It seems like the the sprintf is a memory hoarder and it crashed the arduino when it ran multiple times
sevseg.setChars(buf);
void buttonsCheck() {
bool buttonsState[3];
buttonsState[0] = !digitalRead(SelectButton);
buttonsState[1] = !digitalRead(PlayPauseButton);
if (buttonsState[0] != buttonsPrev[0]) {
buttonsPrev[0] = buttonsState[0];
if (buttonsState[0]) {
if (dispMode < 4) dispMode++;
else dispMode = 0;
buttonsCheck();
switch (dispMode) {
case 0:
displayNumberLetter(realCurrent, 'A');
leds[0] = 0x813afc;
case 1:
displayNumberLetter(realVoltage, 'U');
leds[0] = 0x3acffc;
case 2:
displayNumberLetter(timeHours, 'H');
leds[0] = 0xf59e42;
case 3:
displayNumberLetter(timeMinutes, 'N');
leds[0] = 0xf5d142;
case 4:
displayNumberLetter(realTemperature, '*');
leds[0] = 0xff0000;
FastLED.show();
sevseg.refreshDisplay();
