Create a library
I am trying to create a library Mitch (following the tutorial??).
Here is Mitch.h
  Mitch.h - Library for stepper motor function.
  Created by John Mitchell 23 Mar 2023_1205.
  Released into the mitch domain.
#ifndef Mitch_h
#define Mitch_h
#include "Arduino.h"
class Mitch
  public:
    Mitch(String motorType);
    void setAttributes(String motorType);
//     int no_of_steps;
  private:
    String _motorType;
#endif
Here is Mitch.cpp:
  Mitch.cpp - Library for mitch stepper motors.
  Created by John Mitchell 23 Mar 2023_1228.
#include "Mitch.h"
Mitch::Mitch()
  _motorType = motorType;
void Mitch::setAttributes(String _motorType) {
int no_of_steps = 0;
if (_motorType == "2T35")
    // step = 3.75 deg
    no_of_steps = 360 / 3.75;
  } else if (_motorType == "2T15") {
    //   step = 18 deg
    no_of_steps = 360 / 18;
  } else if (_motorType == "WA42") {
    //  step = 0.9 deg
    no_of_steps = 360 / 0.9;
return no_of_steps;
And here is the Sketch
#include <Mitch.h>
String motor = "WA42";
Mitch mitch;
  int nSteps;
nSteps = mitch.setAttributes(motor);
I get this error
Compilation error: no matching function for call to 'Mitch::Mitch()'
I cannot see my error!
tia
which tutorial are you following?
I suggest before you make a library - make a working sketch with the class in your sketch. Show that sketch too.
a) The error is obvious, you try to create your instance not in the form you have declared the constructor.
b) Why do you need a setter? Is there any need to change motorType during runtime? why call it it set when you return a calculated number?!?
c) Btw: there are for sure better variants to hand over a motor type than to use a String Object.
edit:
just a short POC:
class Mitch {
  public:
    enum Motortype {M2T35, M2T15, MWA42 };
  protected:
    Motortype motortype;
    int steps = 0;
  public:
    Mitch(Motortype motortype) : motortype{motortype} {
      steps = calcNoOfSteps(motortype);
    // an independent mapping of a motortype to steps
    // if re-usage in usersketch would really be necessary
    int calcNoOfSteps(Motortype motortype) {
      switch (motortype) {
        case M2T35 :
        case M2T15 :
          //   step = 18 deg
        case MWA42 :
          //  step = 0.9 deg
      return no_of_steps;
    // just return the internal
    int getNoOfSteps() {
      return steps;
Mitch mitchA(Mitch::M2T35);
Mitch mitchB(Mitch::M2T15);
Mitch mitchC(Mitch::MWA42);
  Serial.println(mitchA.getNoOfSteps());
  Serial.println(mitchB.getNoOfSteps());
  Serial.println(mitchC.getNoOfSteps());
gives:
96
20
400
If you explain a little bit more about what you want to achieve, and what you want the user let to configure at which point, we might come up with a better solution. This could be a base class with the main functionality and inherited children for the motortypes. Or something completely different depending of what you are aiming for...
My guessing is it is a dry exercise to learn how it works to write a library that contains a class.
Of course it is very very common to have objects defined as classes in a library.
If my assumption is true (which might be not) the TO is writing a library which has a class as the very first exercise does two things at once which make it more complicated to understand what is what.
And - like it or hate it - requires a lot of explanation to make it easy to understand.
Without the explanations it is very likely that a newcomer will work this way:
the class that I use as my blue-print has a name in first letter Capital followed by the same charactersequence lowercase in this pattern
This means it is a optical modification without understanding why.
You should add explanations to make it easy to understand the underlying pattern or as an alternative just paste a link to a good tutorial that does explain all details step by step.
best regards Stefan
P.S. After quogling for it Will do exactly this in my own thread
From a quick reading this one seems to be pretty good
https://www.circuitbasics.com/programming-with-classes-and-objects-on-the-arduino/
if it is really good will turn out If have worked through it
Off topic quibbling removed.
Please restrict all further replies to helping @johnmi
to all replies:
I followed the example from Learn "Writing a Library for Arduino". I attempted to transpose exactly my specifics using the the example Morse dash, dot.
@StefanL38 captures my predicament. I am a new comer to Arduino although have some reasonable coding experience. I have several scripts all understanding how to control stepper motors taking various examples in the Web and this forum, and wanted to have a library instead of tweaking multiple times.
So I will look at the example in circuit basic.
tks
tks @StefanL38 - the example and step by step explanation were successful, although ti took some time to identify a missing const in
int motorLib::setAttributes(const String motorType) {
on matters different - what do these mean ?
POC & TO
Proof Of Concept
a full working example you can put in the IDE and let it compile to demonstrate something
Thread Owner
in this case you as the one who started this thread
Interesting! Thank you for the information!
Hi @Delta_G
thannks for your feedback - its been a while (March) and I followed then another different example.
But it is good to have a clear understanding of my error and how to fix it.
