Create an index array
I have the nfc code, I put it in the json uid. I want to index so it doesn't have to be myArray[0] || myArray[1]. How do I set it up?
#include <SPI.h>
#include <MFRC522.h>
#include <Arduino_JSON.h>
#define RST_PIN         D0
#define SS_PIN          D8
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
MFRC522::MIFARE_Key key;
const char input[] = "[\"7C 21 53 49\",\"83 95 E3 1A\",\"04 6A 5A 02 9C 53 80\"]";
const char* arraystring;
    Serial.begin(9600); // Initialize serial communications with the PC
    while (!Serial);
    SPI.begin();        // Init SPI bus
    mfrc522.PCD_Init(); // Init MFRC522 card
    // Prepare the key (used both as key A and as key B)
    // using which is the default at chip delivery from the factory
    for (byte i = 0; i < 6; i++) {
        key.keyByte[i] = 0xFF;
    dump_byte_array(key.keyByte, MFRC522::MF_KEY_SIZE);
    // Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
    if ( ! mfrc522.PICC_IsNewCardPresent())
        return;
    // Select one of the cards
    if ( ! mfrc522.PICC_ReadCardSerial())
        return;
    // Show some details of the PICC (that is: the tag/card)
    Serial.print(F("Card UID:"));
    dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
    Serial.print(F("PICC type: "));
    MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
    Serial.println(mfrc522.PICC_GetTypeName(piccType));
    // Check for compatibility
    if (    piccType != MFRC522::PICC_TYPE_MIFARE_MINI
        &&  piccType != MFRC522::PICC_TYPE_MIFARE_1K
        &&  piccType != MFRC522::PICC_TYPE_MIFARE_4K
        &&  piccType != MFRC522::PICC_TYPE_ISO_14443_4) {
        Serial.println(F("No valid tag"));
        return;
    MFRC522::StatusCode status;
    String content= "";
    get_UID(content);
    // Halt PICC
    mfrc522.PICC_HaltA();
    // Stop encryption on PCD
    mfrc522.PCD_StopCrypto1();
void dump_byte_array(byte *buffer, byte bufferSize) {
    for (byte i = 0; i < bufferSize; i++) {
        Serial.print(buffer[i] < 0x10 ? " 0" : " ");
        Serial.print(buffer[i], HEX);
void get_UID(String content) {
  JSONVar myArray = JSON.parse(input);
  if (JSON.typeof(myArray) == "undefined") {
    Serial.println("Parsing input failed!");
    return;
  for (byte i = 0; i < mfrc522.uid.size; i++)
     content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte[i], HEX));
  content.toUpperCase();
  if (content.substring(1) == myArray[0] || myArray[1]) {
      Serial.println("Tag true");
      Serial.println("Tag false");
You can use a for-loop to iterate through your json array elements and compare.
Not familiar with json on Arduino but I think that this is a bug and should be
if (content.substring(1) == myArray[0] || content.substring(1) == myArray[1])
How do we avoid having to type this just to find myArray[1], myArray[2], myArray[3]
As said, use a for-loop. JSON should have a way to determine how many elements are in myArray. It could look like below; you will have to figure out how to get the length (number of elements) of that myArray.
bool tagFound = true;
for(int cnt = 0; cnt < length_of_myArray; cnt++)
  if (content.substring(1) != myArray[cnt])
    tagFound = false;
I have my doubts that it works because I doubt that myArray is an array of Strings. But as said, not familiar with JSON on Arduino.
Why are you storing your UIDs in a JSON format? That seems like a very bad choice. If you are hard coding them into your sketch, just store them as a uint32_t array.
I tried using 2 cards and one of the cards couldn't be read properly
Screenshot pada 2023-07-26 11-57-34
#include <SPI.h>
#define RST_PIN         D0
#define SS_PIN          D8
    while (!Serial);
        return;
        return;
        return;
    String content= "";
    get_UID(content);
    // Halt PICC
    return;
  for(int cnt = 0; cnt < myArray.length(); cnt++) {
    if (content.substring(1) != myArray[cnt]) {
      tagFound = false;
again, why are you using JSON? Just use a String or a char array...
#include <SPI.h>
//#include <Arduino_JSON.h>
#define RST_PIN         D0
#define SS_PIN          D8
const char *input[] =  { "7C215349", "8395E31A", "046A5A029C5380" };
const int numKeys = sizeof(input) / sizeof(input[0]);
  while (!Serial);
    return;
    return;
    return;
  String content = "";
  get_UID(content);
  // Halt PICC
    if ( mfrc522.uid.uidByte[i] < 0x10 ) {
      content.concat("0");
  bool tagFound = false;
  for (int cnt = 0; cnt < numKeys; cnt++) {
    if ( strcmp(content.c_str(), input[cnt]) == 0) {
      tagFound = true;
  if ( !tagFound ) {
