Create Tolerance In A Variable
I am trying to write a piece of code in a way as to give the if statement a lower tolerance. Im not sure what i should be searching for. If anyone could shed some light it would be greatly appreciated.
output = map(average, 10, 1023, 0, 99);
humidity = sht1x.readHumidity();
if(humidity) < output){  // what i want to do here is give the function a lower tolerance so if output =50 i can use 45- 55 instead.
  digitalWrite(fan, HIGH);
  digitalWrite(fan, LOW);
if((humidity =< output+5) || (humidity => output-5))
Something like that. Untested!
if(humidity >= output -5 && humidity <= output + 5)?
It's not clear what you want to do.
Do you mean "run the fan when the humidity is within 5 points of the specified value"? That would be:
if (humidity >= output - 5 && humidity <= output + 5)
Do you mean "run the fan when the humidity is NOT within 5 points of the specified value"? That would be:
if (humidity < output - 5 || humidity > output + 5)
Sorry, I want the fan to run.
Thank you all, It's sorted.
Much appreciated!
If you want to know when two values are within a certain tolerance of each other you can subtract them and use abs() to get the absolute difference between them. E.g.:
if(abs(target-actual) < tolerance)
   // target and actual are close
   // target and actual are not close
If you are trying to apply hysteresis instead, you can do that using a pair of if/else statements to compare the value to two different thresholds.
