Hello. I am working with GSM modem sim800 and want to create my custom library using classes. I have used TinyGSM library which worked fine but I am not able to follow it properly as it is too complicated and the library developers have been almost dead silent for the last couple of months.
I have come across this forum thread which talks about library with Serial and it has not been solved properly yet.
I am hoping someone might be able to help me here:
My custom_modem.cpp looks like:
#include "custom_modem.h"
#include "Arduino.h"
custom_modem::custom_modem(Stream& serial)
_serial = serial
void custom_modem::send_AT_command(String command)
_serial.write(command);
while (_serial.available())
char c = _serial.read();
Serial.print(c);
and .h file:
#ifndef custom_modem_h
#define custom_modem_h
#include <Arduino.h>
#include <Stream.h>
class custom_modem
public:
custom_modem(Stream& serial);
void send_AT_command(String command);
private:
Stream& _serial;
#endif
in the arduino .ino file I am creating a class object:
#define SerialAT Serial1
custom_modem modem(SerialAT);
The errors I am getting:
sketch\src\custom_modem.cpp: In constructor 'custom_modem::custom_modem(Stream&)':
sketch\src\custom_modem.cpp:5:1: error: uninitialized reference member in 'class Stream&' [-fpermissive]
In file included from sketch\src\custom_modem.cpp:2:0:
sketch\src\custom_modem.h:16:15: note: 'Stream& custom_modem::_serial' should be initialized
Stream& _serial;
sketch\src\custom_modem.cpp: In member function 'void custom_modem::send_AT_command(String)':
sketch\src\custom_modem.cpp:13:26: error: no matching function for call to 'Stream::write(String&)'
In file included from C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Stream.h:26:0,
from C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Arduino.h:147,
from sketch\src\custom_modem.h:5,
C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:61:20: note: candidate: virtual size_t Print::write(uint8_t)
virtual size_t write(uint8_t) = 0;
C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:61:20: note: no known conversion for argument 1 from 'String' to 'uint8_t {aka unsigned char}'
C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:62:12: note: candidate: size_t Print::write(const char*)
size_t write(const char *str)
C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:62:12: note: no known conversion for argument 1 from 'String' to 'const char*'
C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:69:20: note: candidate: virtual size_t Print::write(const uint8_t*, size_t)
virtual size_t write(const uint8_t *buffer, size_t size);
C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:69:20: note: candidate expects 2 arguments, 1 provided
C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:70:12: note: candidate: size_t Print::write(const char*, size_t)
size_t write(const char *buffer, size_t size)
C:\Users\Lukas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:70:12: note: candidate expects 2 arguments, 1 provided
exit status 1
Error compiling for board ESP32 Dev Module.
I want to create a class object and then use this object with other class functions that I am going to create such as sending AT commands to the module, waiting for the response, sending USSD message and etc. Hoping someone can clarify how to properly create a class using Serial or Stream
