So I am new to programming in general and I'm taking a class that requires it. For a project I am wanting to create a random Haiku generator using two or three buttons. I want the first button to give a random 5 syllable phrase, the second button to generate a random 7 syllable phrase, and the third for the last 5 syllable phrase. These phrases will be pre-written so I don't need each word to be random. The Haiku will just need to appear on the serial monitor and I may want a fourth button to clear the screen.
If I could work it out so one button press does the entire Haiku then that could work great too but it's not necessary. I don't need the whole code written out for me, but I would greatly appreciate it if someone could get me on the right track (especially for the random generation part).
Start by looking at the random() and randomSeed() functions
As to the 4th question, do you mean ?
I assume that you know how to read and test the state of an input, or do you ?
If so, then no, it has nothing to do with program errors and everything to do with determining that a button has been pressed and taking action as a result
For instance, do you know how to determine that a button has become pressed rather than when it is pressed ?
