howroyd
December 20, 2011, 5:02pm
1
Anyone know how to create a string of floats?
I want to change:
// Serial.print(timeNow,0);
// Serial.print("\t");
// Serial.print(float1,3);
// Serial.print(float2,2);
// Serial.print(float3,2);
// Serial.print(float4,2);
// Serial.print(float5,2);
// Serial.println("");
Into something like this:
String dataString = "";
dataString += (float1,DEC); // 3 decimal places
dataString += "\t";
dataString += (float2,DEC); // 2 decimal places
dataString += "\t";
dataString += (float3,DEC); // 2 decimal places
dataString += "\t";
dataString += (float4,DEC); // 2 decimal places
dataString += "\t";
dataString += (float1,DEC); // 2 decimal places
dataString += "\t";
dataString += (float5,DEC); // 2 decimal places
dataString += "\n";
Serial.print(dataString);
So the serial output is something like:
1.123 2.23 3.45 4.56 5.67
You can use sprintf to do that:
// make this string long enough to hold all the data
char dataString[128];
// need this to keep track of where the end of the string is;
char *sp;
sp = dataString;
// In the format spec, 5 is the total width of the printed number including sign and decimal point
// 3 (or 2 etc.) is the number of decimal places
sprintf(sp,"%5.3f\t",float1);
sp = dataString + strlen(dataString);
sprintf(sp,"%5.2f\t",float2);
sprintf(sp,"%5.2f\n",float5);
Pete
howroyd
December 20, 2011, 5:20pm
3
Pete,
Thanks very much for your help. I've actually just managed to do it using dtostrf, which is apparently better than sprintf:
dtostrf(float1,4,0,buffer);
dataString += buffer;
dataString += "\t";
dtostrf(float2,4,3,buffer);
dataString += "\t";
dtostrf(float3,4,2,buffer);
dataString += "\t";
dtostrf(float4,4,2,buffer);
dataString += "\t";
dtostrf(float5,4,2,buffer);
dataString += "\t";
dtostrf(float6,4,2,buffer);
dataString += "\n";
Produces the output I want too.
Many thanks for your help anyway!
system
December 20, 2011, 7:10pm
4
Actually, you can't. The %f format specifier is not supported on the Arduino.
howroyd
December 20, 2011, 7:15pm
5
I'm getting an interesting problem with this...
I'm running the code at 50Hz, after about 5-6 seconds one of the tabs vanishes.
Is this likely to be a memory problem, where I haven't defined the String size so it's contracting and expanding and problems arising because of this?
system
December 20, 2011, 7:33pm
7
Just the tab character, or the data after it too?
Yes, and no. It is likely to be a memory problem. You can't define the size of a String. It dynamically changes size (and memory usage).
You should get rid of the String object, and use a fixed size char array, instead.
system
December 21, 2011, 5:05am
8
PaulS:
Agreed. I'd use a plain fixed size array, and look into PString to "print" to that string: PString | Arduiniana
