Creating a Wireless Mechanical Push Button
Hi there everyone. I'm looking into projects I want to use my Arduino for and I've been thinking of creating a push button mechanism that I can control using a wireless button or remote.
The idea would be once activated the mechanism would go down onto a button and push it in to activate the electronic. Just like how one would push a button down on a keyboard to type out a letter.
I'm not sure what components I would need though to start this project and I was wondering if anyone knew any similar projects or would know where I could find some components to start building a rough draft?
Thank you for your help
Which force or torque will be required to press the button? Which way or angle?
You may use e.g. a servo, a solenoid or a linear actuator. Almost quite big items compared to a button shape.
IF your project is just to create what you described, NO Arduino is needed. Remotely controlled relays are readily available on EBAY.
I'm thinking a motor for the force. It would be straight up and down
Do you have a link to something like that?
I do, I used two of these: devices on a project for a friend. The receiver has a relay output rated for 1 amp.
What could I use to have the up/down motion to push in the button?
Obviously, something that moves. A solenoid, a servo with an arm or a DC motor with a cam.
So we are back now to my #2 response :slight_smile:
Apparently the OP has never thought of using a relay in place of his switch.
Hello heroice18
You can use a servo to do so.
So it were interesting to learn why not!
