I have to work with a lot of numbers and I need an array that has all of the numbers from 0 to 1500. I want to have some kind of loop that can be defined int the “void setup” function, that will set up the desired array. I was thinking that I could make a “for” loop just keep adding all of the numbers until it hits 1500. Obviously that did not work. lol Bellow you will find one of my attempts to try this.
Any help would be great.
Thanks
const int MaxChars = 1500 ;
int temp[MaxChars+1] ;
int array[] = {1, 2 ,3, 4, 5} ;
for ( int j = 0 ; j < MaxChars - 1 ; j++ )
int num ;
for ( int index = 0 ; index < MaxChars - 1 ; index++ )
temp[index] = num;
Serial.println(temp[1]);
for ( int i = 0 ; i < MaxChars ; i++) {while (i < MaxChars ) {Serial.println(temp[i++]);}}
delay(5000);
If your using an UNO it will not have enough memory to store this array. As the previous poster says, let us know a bit more about what your doing, there are always alternative approaches.
I agree it makes no sense - if the array element indexed by n contains the number n, then why bother storing it there? Why not use the index n by itself?
The only situation I can see this making sense is the "deck of cards" scenario. You have X number of unique numbers, and you want to return them in a random sequence, but each number being unique - like shuffling a deck of cards.
Why you'd want to do that with 1500 cards I have no idea
Please explain what it is you are doing and what you hope to achieve with it.
True, didn't read the code enough to see that, mainly on the basis that 1500 integers would use more memory than the UNO has - unless it's going in progmem ?
In isolation it seems like a strange thing to want to do, but if you want an array consisting of 0, 1, 2, … and so on up to 1499 then you can do that very easily like this:
int temp[MaxChars] ;
for (int i = 0; i < MaxChars; i++ )
temp[i] = i;
[/quote]
If that isn’t what you’re trying to achieve then you’ll have to do a better job of explaining what you want to achieve.
