Creating humidity and temp sensor = DHT11 + LCD + Push button + RGB LED's
I am to use the DHT11 temperature and humidity sensor to measure and display the temperature and humidity using an LCD (i2c) screen. A momentary push-button (not a switch) must be used to read sensor, i.e. the temperature and humidity values are read every time the button is pressed. In the context of environmental monitoring and weather conditions, I am to include another indicator using RGB LED to show if conditions are bad, fair or good depending on the recorded values, i.e. change the color of LED based on the temperature/humidity levels.
This is my code for the DHT11 and the LCD including external libraries (at this point i cannot code without the libraries) :
#include <SimpleDHT.h>
#include <Wire.h>
// for DHT11,
//      VCC: 5V or 3V
//      GND: GND
//      DATA: 2
int pinDHT11 = 2;
SimpleDHT11 dht11(pinDHT11);
LiquidCrystal_I2C lcd(0x27, 16, 2);
  Serial.println("=================================");
  Serial.println("Sample DHT11...");
  byte temperature = 0;
  byte humidity = 0;
  int err = SimpleDHTErrSuccess;
  if ((err = dht11.read(&temperature, &humidity, NULL)) != SimpleDHTErrSuccess) {
    Serial.print("Read DHT11 failed, err="); Serial.println(err);delay(1000);
    return;
    lcd.begin();
  lcd.backlight();
  lcd.print("tempature  "); lcd.print((int)temperature);
  lcd.setCursor(0, 1);
  lcd.print("humidity  ");
  lcd.print((int)humidity);
I need help to (1) incorporate all the elements into the code, (2) write the code without external libraries for the DHT11 and LCD.
Thanks!
Topic closed as it is a duplicate of Using DHT11 temp. and humidity sensor to measure & display the temp and humidity using an LCD without using any external libraries
