My first post ![]()
I am attempting to create a main class that holds info on menu navigation. Inside that class are multiple sub-classes that have different array lengths depending values sent to them at compile time. It should also be able to send a pointer from a 2D array to the subclasses so that I can work with reading that 2D array inside the main class.
It works like this: in main I create a const char* array that has multiple strings which I believe is a pointer to program flash memory. I also create an instance of 'DisplayControl' and send it 5 and the array [2,5,3,5,1] which tells it to create 5 submenu classes, 'DisplayMenu', and initiate them with internal menu lengths of the array. Then I would call a link function which transfers the address of the 2D array in main to a pointer inside the submenu classes.
This link Class inside a class shows how to create a class inside a class but only if you know how many classes are being created (not by variable).
I have tried many different things to pass the reference inside just a single class but to no avail. Here is some code that I have come up with just to get the idea across but it is full of errors.
Main:
#include "DisplayControl.h"
DisplayControl MyDisplay(5, [2,5,3,5,1]); //create a DisplayControl with 5 menus, each being 2,5,3,5, and 1 long
//Menu description to draw for menu 1
const char* LED_DescMatrix[] = {
"GoSteps:", //menu item 1
"MS :", //menu item 2
"Stp/Deg:", //menu item 3
"CurrPos:", //menu item 4
"Degrees:" //menu item 5
//supposed to push LED_DescMatrix to the pointer in MyMenu[1] so that I can work with it in the class
MyDisplay.PushDescToMenu(1, LED_DescMatrix);
The main class:
#ifndef DISPLAYCONTROL_H
#define DISPLAYCONTROL_H
#include "DisplayMenu.h"
class DisplayControl
public:
DisplayControl(byte NumberOfMenus, byte *MenuSizes[]); //constructor
void PushDescToMenu(byte WhichMenu, const char *DescPointer1); //pushes pointer of desc to each MyMenu pointer
private:
byte MenuHeight; //Limited display height of the screen
byte ActiveMenu; //which menu is active -> in MyMenus[x]
byte DescriptionLength; //how much of the description to show
DisplayMenu MyMenus[]; //creating class within a class with size of variable input
#endif
cpp file
DisplayControl::DisplayControl(byte NumberOfMenus, byte *MenuSizes[]) : //how to initialize variable 'MyMenu's here and pass 'MenuSizes[]' to each one?
//DisplayMenu MyMenu[NumberOfMenus]
//not going to work =(
for (i=0; i<NumberOfMenus; i++)
DisplayMenu MyMenu(MenuSizes[i]);
void DisplayControl::PushDescToMenu(byte WhichMenu, const char *DescPointer1)
MyMenu[WhichMenu].LinkDesc(DescPointer1);
The subclass:
#ifndef DISPLAYMENU_H
#define DISPLAYMENU_H
class DisplayMenu
public:
DisplayMenu(int MenuSize); //constructor
int CurrentIndex_X; //menu x position
int CurrentIndex_Y; //menu y position
int MenuStart; //which global y position to start displaying menu
//This should have an array size of 'MenuSize' from above... not working yet
const char *MenuDescription[5]; //pointer to 2 dim array of menu description
void LinkDesc(const char* DescPointer2); //FUNC. takes pointer from main and stores it in Description
private:
#endif
cpp file
DisplayMenu::DisplayMenu(int MenuSize)
CurrentIndex_X=0;
CurrentIndex_Y=0;
MenuStart=0;
void DisplayMenu::LinkDesc(const char* DescPointer2)
MenuDescription = DescPointer2;
Any help would be appreciated. I have another way to do what I want but it requires a crap ton of index keeping and one big array.
Cheers!
