Thanks @J-M-L and @jfjlaros
I've seen the initialiser lists before but never cared to look deeper into them; now I've learned something (never too old) but still need to study it a bit more.
Is my understanding correct that I can leave the ezLED library as is (no initialiser list required) and only need to implement it in the IndicatorControl class? I've tried it both ways and they both seem to work.
It was a bit of a nightmare to implement and actually had to start from scratch to figure out where I went wrong
This is what I came up with (as a minimal example); the ezLED library has a bug (pinMode used in the constructor) so I made a local copy, modified it and included that.
ezLED.h
* Copyright (c) 2021, ArduinoGetStarted.com. All rights reserved.
// modified by sterretje on forum.arduino.cc 2023
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* - Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* - Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* - Neither the name of the ArduinoGetStarted.com nor the names of its
* contributors may be used to endorse or promote products derived from
* this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY ARDUINOGETSTARTED.COM "AS IS" AND ANY EXPRESS OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL ARDUINOGETSTARTED.COM BE LIABLE FOR ANY DIRECT,
* INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
* STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
#ifndef ezLED_h
#define ezLED_h
#include <Arduino.h>
#define LED_OFF 0
#define LED_ON 1
#define LED_IDLE 0
#define LED_DELAY 1
#define LED_FADING 2
#define LED_BLINKING 3
#define CTRL_ANODE 0
#define CTRL_CATHODE 1
#define LED_MODE_OFF 0
#define LED_MODE_ON 1
#define LED_MODE_TOGGLE 2
#define LED_MODE_FADE 3
#define LED_MODE_BLINK_FOREVER 4
#define LED_MODE_BLINK_PERIOD 5
#define LED_MODE_BLINK_NUM_TIME 6
#define LED_STATE_IDLE 0
#define LED_STATE_DELAY 1
#define LED_STATE_ON_OFF 2
#define LED_STATE_FADE 3
#define LED_STATE_BLINK 4
class ezLED
private:
int _ledPin;
unsigned char _ctrlMode; // CTRL_ANODE, CTRL_CATHODE
unsigned char _ledMode;
unsigned char _ledState;
unsigned char _outputState; // LED_OFF, LED_ON
int _brightness; // 0 to 255
unsigned char _fadeFrom = 0;
unsigned char _fadeTo = 0;
unsigned long _fadeTime;
unsigned long _blinkOnTime;
unsigned long _blinkOffTime;
unsigned long _blinkTimePeriod;
unsigned int _blinkNumberOfTimes;
unsigned long _delayTime;
unsigned long _lastTime;
unsigned long _blinkTimer;
unsigned int _blinkCounter;
void setBlink(unsigned long onTime, unsigned long offTime, unsigned long delayTime);
void updateAnalog();
void updateDigital();
public:
ezLED(int pin, int mode = CTRL_ANODE);
void begin();
void turnON(unsigned long delayTime = 0);
void turnOFF(unsigned long delayTime = 0);
void toggle(unsigned long delayTime = 0);
void fade(int fadeFrom, int fadeTo, unsigned long fadeTime, unsigned long delayTime = 0);
void blink(unsigned long onTime, unsigned long offTime, unsigned long delayTime = 0);
void blinkInPeriod(unsigned long onTime, unsigned long offTime, unsigned long blinkTime, unsigned long delayTime = 0);
void blinkNumberOfTimes(unsigned long onTime, unsigned long offTime, unsigned int numberOfTimes, unsigned long delayTime = 0);
void cancel(void);
int getOnOff(void);
int getState(void);
void loop(void);
#endif
ezLED.cpp
* are met:
//#include <ezLED.h>
#include "z_ezLED.h"
ezLED::ezLED(int pin, int mode)
// : _ledPin(pin), _ctrlMode(mode)
_ledPin = pin;
_ctrlMode = mode; // CTRL_ANODE, CTRL_CATHODE
_ledMode = LED_MODE_OFF;
_ledState = LED_STATE_IDLE;
_outputState = LED_OFF; // LED_OFF, LED_ON
_brightness = 0; // 0 to 255
_fadeFrom = 0;
_fadeTo = 0;
_fadeTime = 0;
_blinkOnTime = 0;
_blinkOffTime = 0;
_blinkTimePeriod = 0;
_blinkNumberOfTimes = 0;
_delayTime = 0;
_lastTime = 0;
_blinkTimer = 0;
_blinkCounter = 0;
void ezLED::begin()
pinMode(_ledPin, OUTPUT);
void ezLED::setBlink(unsigned long onTime, unsigned long offTime, unsigned long delayTime)
_blinkOnTime = onTime;
_blinkOffTime = offTime;
_delayTime = delayTime;
_lastTime = millis();
void ezLED::updateAnalog()
if (_ctrlMode == CTRL_ANODE)
analogWrite(_ledPin, _brightness);
analogWrite(_ledPin, 255 - _brightness);
void ezLED::updateDigital()
int state;
state = (_outputState == LED_OFF) ? LOW : HIGH;
state = (_outputState == LED_OFF) ? HIGH : LOW;
digitalWrite(_ledPin, state);
void ezLED::turnON(unsigned long delayTime)
_ledMode = LED_MODE_ON;
if (delayTime > 0)
_ledState = LED_STATE_DELAY;
_ledState = LED_STATE_ON_OFF;
loop();
void ezLED::turnOFF(unsigned long delayTime)
if (delayTime > 0)
loop();
void ezLED::toggle(unsigned long delayTime)
_ledMode = LED_MODE_TOGGLE;
if (delayTime > 0)
loop();
void ezLED::fade(int fadeFrom, int fadeTo, unsigned long fadeTime, unsigned long delayTime)
_fadeFrom = fadeFrom;
_fadeTo = fadeTo;
_fadeTime = fadeTime;
_ledMode = LED_MODE_FADE;
if (delayTime > 0)
_ledState = LED_STATE_FADE;
loop();
void ezLED::blink(unsigned long onTime, unsigned long offTime, unsigned long delayTime)
setBlink(onTime, offTime, delayTime);
_ledMode = LED_MODE_BLINK_FOREVER;
if (_ledState == LED_STATE_IDLE)
if (delayTime > 0)
_ledState = LED_STATE_BLINK;
_outputState = LED_ON;
loop();
void ezLED::blinkInPeriod(unsigned long onTime, unsigned long offTime, unsigned long blinkTime, unsigned long delayTime)
_blinkTimePeriod = blinkTime;
_ledMode = LED_MODE_BLINK_PERIOD;
if (delayTime > 0)
_blinkTimer = millis();
loop();
void ezLED::blinkNumberOfTimes(unsigned long onTime, unsigned long offTime, unsigned int numberOfTimes, unsigned long delayTime)
_blinkNumberOfTimes = numberOfTimes;
_ledMode = LED_MODE_BLINK_NUM_TIME;
if (delayTime > 0)
_blinkCounter = 1;
loop();
void ezLED::cancel(void)
turnOFF();
int ezLED::getOnOff(void)
return _outputState;
int ezLED::getState(void)
switch (_ledState)
case LED_STATE_DELAY:
return LED_DELAY;
case LED_STATE_FADE:
return LED_FADING;
case LED_STATE_BLINK:
return LED_BLINKING;
default:
return LED_IDLE;
void ezLED::loop(void)
switch (_ledState)
case LED_STATE_IDLE:
return;
if ((unsigned long)(millis() - _lastTime) >= _delayTime)
switch (_ledMode)
case LED_MODE_OFF:
case LED_MODE_ON:
case LED_MODE_TOGGLE:
case LED_MODE_FADE:
case LED_MODE_BLINK_FOREVER:
case LED_MODE_BLINK_PERIOD:
case LED_MODE_BLINK_NUM_TIME:
case LED_STATE_ON_OFF:
switch (_ledMode)
case LED_MODE_OFF:
case LED_MODE_ON:
_outputState = (_outputState == LED_ON) ? LED_OFF : LED_ON;
if ((millis() - _lastTime) <= _fadeTime)
unsigned long progress = millis() - _lastTime;
_brightness = map(progress, 0, _fadeTime, _fadeFrom, _fadeTo);
if (_outputState == LED_OFF && (unsigned long)(millis() - _lastTime) >= _blinkOffTime)
_blinkCounter++;
else if (_outputState == LED_ON && (unsigned long)(millis() - _lastTime) >= _blinkOnTime)
_blinkCounter++;
switch (_ledMode)
if ((unsigned long)(millis() - _blinkTimer) >= _blinkTimePeriod)
if (_blinkCounter >= (2 * _blinkNumberOfTimes))
default:
Serial.println(F("UNKNOW STATE"));
if (_ledState == LED_STATE_FADE)
updateAnalog();
updateDigital();
ino file
class IndicatorControl
enum class IndicatorStatus
Off,
Left,
Right,
Hazards
private:
uint8_t _pinLeft;
uint8_t _pinRight;
ezLED _indicatorLeft;
ezLED _indicatorRight;
uint32_t _blinkInterval;
IndicatorStatus _status = IndicatorStatus::Off;
IndicatorStatus _prevStatus = IndicatorStatus::Hazards;
public:
IndicatorControl(uint8_t pinLeft, uint8_t pinRight, uint32_t blinkInterval)
: _pinLeft(pinLeft), _pinRight(pinRight), _indicatorLeft(pinLeft), _indicatorRight(_pinRight), _blinkInterval(blinkInterval)
void begin()
pinMode(_pinLeft, OUTPUT);
pinMode(_pinRight, OUTPUT);
_indicatorLeft.cancel();
_indicatorRight.cancel();
void setOff()
if (_status != _prevStatus)
_status = _prevStatus;
void setLeft()
_indicatorLeft.blink(_blinkInterval, _blinkInterval);
_status = IndicatorStatus::Left;
void setRight()
_indicatorRight.blink(_blinkInterval, _blinkInterval);
_status = IndicatorStatus::Right;
void setHazards()
// cancel first to make sure that they will be in sync
// blink
_status = IndicatorStatus::Hazards;
void control()
switch (_status)
case IndicatorStatus::Off:
case IndicatorStatus::Left:
_indicatorLeft.loop();
case IndicatorStatus::Right:
_indicatorRight.loop();
case IndicatorStatus::Hazards:
const uint8_t pinR = 22;
const uint8_t pinL = 23;
IndicatorControl indicatorControl(pinL, pinR, 500);
Serial.begin(2000000);
indicatorControl.begin();
if (Serial.available() > 0)
char ch = Serial.read();
switch (ch)
case 'o':
indicatorControl.setOff();
case 'l':
indicatorControl.setLeft();
case 'r':
indicatorControl.setRight();
case 'h':
indicatorControl.setHazards();
indicatorControl.control();
@noiasca , thanks for the suggestion. It's not my code so I'm reluctant to change it; just trying to help somebody. Too many changes might not be the way to go (it's already a lot of changes).
