Hello, I have been trying to fix this code for over a week and would now like to turn this forum for some help. Just a general overview, I am using an Arduino Mega for a project to store water quality data from Total dissolved solid (TDS), DO, turbidity and temperature sensors. 3 of the 4 are analog, one digital. I have all the sensors working and reading data into the serial monitor, but nothing shows up in the .csv file "LOGGER00X" that gets created with each run. Right now I have multiple headers set up but am only trying to log data from one sensor to start (the TDS value). Code verifies fine for my board. I tried the SD datalogger example in the IDE and that worked fine (created a file and saved the data to it), so I know it shouldn't be an issue with my hardware. I am very new to this so please don't judge my code if there is a glaring / super obvious problem causing this for me. TYIA
Hardware:
-Arduino Mega 2560 R3 board stacked with
-DF robot expansion shield for the mega board (https://www.robotshop.com/en/dfrobot-mega-io-expansion-shield-arduino-mega.html?gclid=CjwKCAjw4qCKBhAVEiwAkTYsPNrRPs75XVy7t8GMiWq4WbdRSCeMp8QzLWiwh3MvcCZgPFWvWQWDIhoCItkQAvD_BwE)
-Adafruit datalogging shield stacked on top of the expansion shield (https://cdn-learn.adafruit.com/downloads/pdf/adafruit-data-logger-shield.pdf)
Code:
//Mega board with TDS on A11, DO on A12, Turbidity on A13, Temp probe on Digital pin 14
//Notes: As of 9/20/2021 cannot get data to print to SD card. Files are created but empty
/*** SD Code***/
#include "SD.h"
//#include <SPI.h>
#include <Wire.h>
#include "RTClib.h"
#define LOG_INTERVAL 100 // mills between entries
#define SYNC_INTERVAL 100 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 1 // echo data to serial port
RTC_PCF8523 RTC_SD; // define the Real Time Clock object- need to refer to the one on the mircrocontroller ATmega2560
// for the DFrobot Mega shield w/ micro SD , we use digital pin 53 on the Mega (10 for normal boards and SD shield) for the SD cs line
const int chipSelect = 10;
/*** TDS Code***/
#define TdsSensorPin A11
const int VREF = 5.0; // analog reference voltage(Volt) of the ADC (Analog to Digital Converter)
const int SCOUNT = 30; // sum of sample point
int analogBuffer[SCOUNT]; // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0, copyIndex = 0;
float averageVoltage = 0, tdsValue = 0, temperature = 25;
/*** DO Sensor Code***/
#include <Arduino.h>
#define DO_PIN A12
#define VREF 5000 //VREF (mv)
#define ADC_RES 1024 //ADC Resolution
//Single-point calibration Mode=0
//Two-point calibration Mode=1
#define TWO_POINT_CALIBRATION 0
#define READ_TEMP (25) //Current water temperature ℃, Or temperature sensor function--- should this be using info from temp sensor?
//Single point calibration needs to be filled CAL1_V and CAL1_T
#define CAL1_V (1600) //mv
#define CAL1_T (25) //℃
//Two-point calibration needs to be filled CAL2_V and CAL2_T
//CAL1 High temperature point, CAL2 Low temperature point
#define CAL2_V (1300) //mv
#define CAL2_T (15) //℃
const uint16_t DO_Table[41] = {
14460, 14220, 13820, 13440, 13090, 12740, 12420, 12110, 11810, 11530,
11260, 11010, 10770, 10530, 10300, 10080, 9860, 9660, 9460, 9270,
9080, 8900, 8730, 8570, 8410, 8250, 8110, 7960, 7820, 7690,
7560, 7430, 7300, 7180, 7070, 6950, 6840, 6730, 6630, 6530, 6410
uint8_t Temperaturet;
uint16_t ADC_Raw;
uint16_t ADC_Voltage;
uint16_t DO;
int16_t readDO(uint32_t voltage_mv, uint8_t temperature_c)
#if TWO_POINT_CALIBRATION == 0
uint16_t V_saturation = (uint32_t)CAL1_V + (uint32_t)35 * temperature_c - (uint32_t)CAL1_T * 35;
return (voltage_mv * DO_Table[temperature_c] / V_saturation);
#else
uint16_t V_saturation = (int16_t)((int8_t)temperature_c - CAL2_T) * ((uint16_t)CAL1_V - CAL2_V) / ((uint8_t)CAL1_T - CAL2_T) + CAL2_V;
#endif
/*** Temp Probe Code***/
#include <OneWire.h>
int DS18S20_Pin = 14; //DS18S20 Signal pin on digital 14
//Temperature chip i/o
OneWire ds(DS18S20_Pin);
/*** SD Code***/
// the logging file
File logfile;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
while (1);
Serial.begin(115200); //Same BAUD rate for all sensors
//SD Code//
Serial.println("Serial Up!");
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i / 10 + '0';
filename[7] = i % 10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
logfile.close(); //Do I need to remove this to stop it from closing every time?
if (! logfile)
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
//my code, not JJ's
RTC_SD.begin(); //given error message about rtc being pointer type
RTC_SD.adjust(DateTime(__DATE__, __TIME__)); //Set up the date/time to match computer
//RTC_SD.setTime();//write time to chip
Wire.begin();
if (!RTC_SD.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("millis,datetime,TDS,DO temp, DO ADC, DO Volt,DO, Turb, Water temp");
#if ECHO_TO_SERIAL
Serial.println("millis,datetime,TDS,DO temp, DO ADC, DO Volt,DO, Turb, Water temp");
#endif ECHO_TO_SERIAL// attempt to write out the header to the file
// if (logfile.write_error || !logfile.sync()) {
// error("write header");
// // If you want to set the aref to something other than 5v
// analogReference(EXTERNAL);
// pinMode(13, OUTPUT);
// ec.begin();
// pinMode(TdsSensorPin, INPUT);
//TDS Code
pinMode(TdsSensorPin, INPUT); // No DO or turbidity code needed in Set up
//SD code//
DateTime now; now = RTC_SD.now(); // this differs from JJ's code
// delay for the amount of time we want between readings
delay((LOG_INTERVAL - 1) - (millis() % LOG_INTERVAL));
// log milliseconds since starting
uint32_t m = millis();
logfile.print("ms since start: ");
logfile.print(m); // milliseconds since start
logfile.println(", ");
#if ECHO_TO_SERIAL
Serial.print("ms since start: ");
Serial.println(m); // milliseconds since start
#endif
// if (! SD.exists(filename)) {
logfile = SD.open("TESTFILE.CSV", FILE_WRITE);
// break; // leave the loop! Unable to open and write to file
logfile.write("STARTING THE LOG FILE");
// fetch the time
// now = DateTime RTC.now();
// log time
// logfile.print(now); // seconds since 2000
logfile.print("datetime:");
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
// Serial.print(now()); // seconds since 2000
Serial.print("datetime: ");
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.println(now.second(), DEC);
// TDS Code
static unsigned long analogSampleTimepoint = millis();
if (millis() - analogSampleTimepoint > 40U) //every 40 milliseconds,read the analog value from the ADC
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin); //read the analog value and store into the buffer
analogBufferIndex++;
if (analogBufferIndex == SCOUNT)
analogBufferIndex = 0;
static unsigned long printTimepoint = millis();
if (millis() - printTimepoint > 800U)
for (copyIndex = 0; copyIndex < SCOUNT; copyIndex++)
analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
averageVoltage = getMedianNum(analogBufferTemp, SCOUNT) * (float)VREF / 1024.0; // read the analog value more stable by the median filtering algorithm, and convert to voltage value
float compensationCoefficient = 1.0 + 0.02 * (temperature - 25.0); //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
float compensationVolatge = averageVoltage / compensationCoefficient; //temperature compensation
tdsValue = (133.42 * compensationVolatge * compensationVolatge * compensationVolatge - 255.86 * compensationVolatge * compensationVolatge + 857.39 * compensationVolatge) * 0.5; //convert voltage value to tds value
//Serial.print("voltage:");
//Serial.print(averageVoltage,2);
//Serial.print("V ");
Serial.print("TDS Value:");
Serial.print(tdsValue, 0);
Serial.println("ppm");
// DO Code
Temperaturet = (uint8_t)READ_TEMP;
ADC_Raw = analogRead(DO_PIN);
ADC_Voltage = uint32_t(VREF) * ADC_Raw / ADC_RES;
Serial.print("DO Calibration Temperature (C):\t" + String(Temperaturet) + "\t");
Serial.print("ADC RAW:\t" + String(ADC_Raw) + "\t");
Serial.print("ADC Voltage:\t" + String(ADC_Voltage) + "\t");
Serial.print("DO:\t" + String(readDO(ADC_Voltage, Temperaturet)) + "\t");
Serial.println(" ug/L");
// Turbidity Code
int sensorValue = analogRead(A13);//
float voltage = sensorValue * (5.0 / 1024.0); // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
//Serial.println(voltage); // print out the value you read:
Serial.print("Turbidity:" + String(voltage) );
Serial.println(" NTU");//add units
//Temp Probe Code
float temperature = getTemp();
Serial.print("Water Temperature (C):");
Serial.println(temperature);
Serial.print("\n");
int getMedianNum(int bArray[], int iFilterLen)
int bTab[iFilterLen];
for (byte i = 0; i < iFilterLen; i++)
bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++)
for (i = 0; i < iFilterLen - j - 1; i++)
if (bTab[i] > bTab[i + 1])
bTemp = bTab[i];
bTab[i] = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0)
bTemp = bTab[(iFilterLen - 1) / 2];
bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
float getTemp() {
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
// float temperature = getTemp();
return TemperatureSum;
delay(1000); //wait 1 seconds writing to SD file
logfile.print(", ");
logfile.print(tdsValue);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.println(tdsValue);
Serial.print("Closing logfile");
logfile.close();
