I want to ask if there is a way to make a curl call with arduino uno and arduino wifi shield?
Thanks,
Guy Yanai
Thanks,
Guy Yanai
This sounds like an X-Y problem. What is it that you actually want to do?
Curl is a command line tool for computers, it doesn't work on Arduino. However, the underlying principles are supported using the WiFi shield, like establishing TCP connections, sending HTTP requests ...
Pieter
I got a google form and I want to get in it with prefilled data from the Arduino WIFI Shield.
The prefilled URL:
https://docs.google.com/forms/d/e/*SECRETFORMID*/formResponse?&ifq&*SECRETENTERY*=*DATA1*&*SECRETENTERY*=*DATA2*&submit=Submit
I got a server that does the https creating work for me so what I really need is to get in a website.
URL:
http://SecretServerName/test.asp?d1=DATA&d2=DATA
You don't need cURL, you need HTTP. Read more here.
Take a look at this example to establish a TCP connection with the server, then send your HTTP request over that connection.
Pieter
I am interested to know if there is a working solution at all to this question since I am facing the same problems. The Web Client example does not work once POST method is used and kept returning error as specified in this link https://forum.arduino.cc/index.php?topic=550578.0 which is still unsolved!
And looking for the solution is like a Catch 22 and it goes into an unterminated loop nightmare because I cannot find the solution to either X or Y problem. I believe this question by the thread starter is valid since Arduino Uno + ESP8266 Wifi Shield is a friggin deadlock half baked combination.
While it is so easy to suggest all sorts of theoritically correct solution, no practical solution can be found on the internet.
