Thanks!
I found the ESP_WiFiManager library documentation (GitHub - khoih-prog/ESP_WiFiManager: This is an ESP32 / ESP8266 WiFi Connection Manager with fallback web configuration portal. Use this library for configuring ESP32, ESP8266 modules' WiFi, etc. Credentials at runtime. You can also specify static DNS servers, personalized HostName, fixed or random AP WiFi channel. With examples supporting ArduinoJson 6.0.0+ as well as 5.13.5- .) and there explains more or less how to do it. I managed to make a field to add the place:
ESP_WiFiManager ESP_wifiManager("ConfigOnSwitchFS");
ESP_wifiManager.setMinimumSignalQuality(-1);
ESP_WMParameter custom_place("Place", "Place", placeWifi, 60);
ESP_wifiManager.addParameter(&custom_place);
But I cannot record this information. I don’t know where I might be going wrong. Follow the code for anyone who can help or assist me in something, I really don’t know what it is:
#include <ArduinoJson.h>
#include <SPIFFS.h>
#include <ESP_WiFiManager.h>
#define ESP_getChipId() ((uint32_t)ESP.getEfuseMac())
String ssid = "ESP_" + String(ESP_getChipId(), HEX);
const char* password = "your_password";
// SSID and PW for your Router
String Router_SSID;
String Router_Pass;
// Indicates whether ESP has WiFi credentials saved from previous session
bool initialConfig = false;
// Use true for dynamic DHCP IP, false to use static IP and you have to change the IP accordingly to your network
#define USE_DHCP_IP true
// Use DHCP
IPAddress stationIP = IPAddress(0, 0, 0, 0);
IPAddress gatewayIP = IPAddress(192, 168, 2, 1);
IPAddress netMask = IPAddress(255, 255, 255, 0);
IPAddress dns1IP = gatewayIP;
IPAddress dns2IP = IPAddress(8, 8, 8, 8);
bool firstConnection = false;
bool shouldSaveConfig = false;
char placeWifi[60];
connectWifi();
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
readConfigFile();
Serial.println("failed to mount");
if (firstConnection)
check_status();
Serial.println("PLACE");
Serial.println(placeWifi);
void heartBeatPrint(void)
static int num = 1;
if (WiFi.status() == WL_CONNECTED)
Serial.print("H"); // H means connected to WiFi
Serial.print("F"); // F means not connected to WiFi
if (num == 80)
num = 1;
else if (num++ % 10 == 0)
Serial.print(" ");
/*FUNÇÃO QUE CONECTA O ESP32 A REDE WIFI*/
void check_status() {
// is configuration portal requested?
Serial.println("\nConfiguration portal requested.");
ESP_wifiManager.setSaveConfigCallback(saveConfigCallback);
if (shouldSaveConfig)
writeConfigFile();
ESP_wifiManager.setSTAStaticIPConfig(stationIP, gatewayIP, netMask, dns1IP, dns2IP);
Serial.print("Opening configuration portal. ");
Router_SSID = ESP_wifiManager.WiFi_SSID();
if (Router_SSID != "")
ESP_wifiManager.setConfigPortalTimeout(120);
Serial.println("Got stored Credentials. Timeout 120s");
Serial.println("No stored Credentials. No timeout");
if (!ESP_wifiManager.startConfigPortal((const char *) ssid.c_str(), password))
Serial.println("Not connected to WiFi but continuing anyway.");
Serial.println("connected...yeey :)");
Serial.print("Local IP: ");
static ulong checkstatus_timeout = 0;
#define HEARTBEAT_INTERVAL 10000L
// Print hearbeat every HEARTBEAT_INTERVAL (10) seconds.
if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
heartBeatPrint();
checkstatus_timeout = millis() + HEARTBEAT_INTERVAL;
void connectWifi()
Serial.println("\nStarting ConfigOnSwitch on " + String(ARDUINO_BOARD));
unsigned long startedAt = millis();
ESP_WiFiManager ESP_wifiManager("ConfigOnSwitch");
ESP_wifiManager.setDebugOutput(true);
Router_Pass = ESP_wifiManager.WiFi_Pass();
Serial.println("Stored: SSID = " + Router_SSID + ", Pass = " + Router_Pass);
ssid.toUpperCase();
if (Router_SSID == "")
Serial.println("Open Config Portal without Timeout: No stored Credentials.");
Serial.println("WiFi connected...yeey :)");
#define WIFI_CONNECT_TIMEOUT 2000L
#define WHILE_LOOP_DELAY 200L
#define WHILE_LOOP_STEPS (WIFI_CONNECT_TIMEOUT / ( 3 * WHILE_LOOP_DELAY ))
while ( (WiFi.status() != WL_CONNECTED) && (millis() - startedAt < WIFI_CONNECT_TIMEOUT ) )
WiFi.mode(WIFI_STA);
WiFi.persistent (true);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(Router_SSID);
WiFi.config(stationIP, gatewayIP, netMask);
//WiFi.config(stationIP, gatewayIP, netMask, dns1IP, dns2IP);
WiFi.begin(Router_SSID.c_str(), Router_Pass.c_str());
int i = 0;
while ((!WiFi.status() || WiFi.status() >= WL_DISCONNECTED) && i++ < WHILE_LOOP_STEPS)
delay(WHILE_LOOP_DELAY);
Serial.print("After waiting ");
Serial.print((millis() - startedAt) / 1000);
Serial.print(" secs more in setup(), connection result is ");
// conectado = 1;
Serial.print("connected. Local IP: ");
void streamTimeoutCallback(bool timeout)
if (timeout) {
Serial.println("Stream timeout, resume streaming...");
bool writeConfigFile()
Serial.println("Saving...");
DynamicJsonDocument json(1024);
json["Place"] = placeWifi;
File f = SPIFFS.open("/placeWifi.json", "w");
if (!f)
return false;
serializeJsonPretty(json, Serial);
serializeJson(json, f);
f.close();
Serial.println("Sucess");
return true;
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
bool readConfigFile()
File f = SPIFFS.open("/placeWifi.json", "r");
if (!f)
Serial.println("Configuration file not found");
return false;
size_t size = f.size();
std::unique_ptr<char[]> buf(new char[size + 1]);
f.readBytes(buf.get(), size);
f.close();
auto deserializeError = deserializeJson(json, buf.get());
if ( deserializeError )
Serial.println("JSON parseObject() failed");
return false;
serializeJson(json, Serial);
if (json.containsKey("Place"))
strcpy(placeWifi, json["Place"]);
Serial.println("\nConfig file was successfully parsed");
return true;
Thanks again.
