Hi everyone,
I am still trying to get my own functions to work. I would like to implement them to get cleaner main code and also to learn how to write functions. The functions in my which (seem) not to work are dataToSD() and dataToSerial().
I end up with error logfile all the time. The serial monitor will also end after the setup. So the problem seems to be in the loop, and especially in the custom functions. But I dont understand wheres the error.
#include <DHT.h>
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
// climatic parameters //////////////////////////////////////////
const byte maxTemp = 29;
const byte normTemp = 26;
const byte minHum = 85;
const byte minHumFan = 80;
// state declaration and control timings ////////////////////////
const unsigned long rainDuration = 5000;
unsigned long previousRain = 0;
const unsigned long rainFanDuration = 3000;
unsigned long previousRainFan = 0;
const unsigned long logFrequency = 30000;
unsigned long previousLog = 0;
unsigned long previousSerialLog = 0;
const unsigned long serialFrequency = 1000;
byte fanState = 0;
byte rainState = 0;
byte i = 0;
byte k = 0;
float t_1;
float t_2;
float h_1;
float h_2;
// pin assignments //////////////////////////////////////////////
const byte switchPin = 4;
const byte DHTPIN_1 = 5;
const byte DHTPIN_2 = 6;
const byte fanRelay = 7;
const byte rainRelay = 8;
const byte chipSelect = 10;
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define DHTTYPE DHT22
DHT dht_1(DHTPIN_1, DHTTYPE);
DHT dht_2(DHTPIN_2, DHTTYPE);
RTC_DS1307 rtc;
File myFile;
char dateBuffer[12];
char sensBuffer[10];
Serial.begin(57600);
while (!Serial) {
lcd.init();
lcd.backlight();
lcd.setCursor(0, 0);
if (! rtc.begin()) {
error("No RTC");
Serial.flush();
abort();
if (! rtc.isrunning()) {
error("RTC was off. Setting new time.");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
//rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
Serial.print(F("Initializing SD card..."));
if (!SD.begin(chipSelect)) {
error("SD initialization failed");
while (1);
Serial.println(F("initialization done."));
if (SD.exists("terralog.txt")) {
Serial.println(F("terralog.txt exists."));
Serial.println(F("terralog.txt doesn't exist."));
Serial.println(F("Creating terraaaaa.txt"));
Serial.println(F("terralog.txt was successfully created."));
Serial.println(F("File creation failed."));
myFile = SD.open("terralog.txt", FILE_WRITE);
myFile.println("date,time,temp_1,temp_2,hum_1,hum_2,fanState, rainState,i,k,rainTime,rainTimeFan,minHum,minHumFan");
myFile.close(); //this might be uncommented later
pinMode(switchPin, INPUT);
pinMode(fanRelay, OUTPUT);
pinMode(rainRelay, OUTPUT);
dht_1.begin();
dht_2.begin();
Serial.println(F("date,time,temp_1,temp_2,hum_1,hum_2,fanState, rainState,i,k,rainTime,rainTimeFan,minHum,minHumFan"));
while (switchPin == HIGH) {
unsigned long currentTime = millis();
h_1 = dht_1.readHumidity();
t_1 = dht_1.readTemperature();
while (isnan(h_1) || isnan(t_1)) {
error("DHT 1");
h_2 = dht_2.readHumidity();
t_2 = dht_2.readTemperature();
while (isnan(h_2) || isnan(t_2)) {
error("DHT 2");
DateTime time = rtc.now();
lcd.print(t_1);
lcd.print(", ");
lcd.print(h_1);
lcd.setCursor(0, 1);
lcd.print(t_2);
lcd.print(", ");
lcd.print(h_2);
// Temperature Control
if (t_2 >= maxTemp) {
fanState = 1;
digitalWrite(fanRelay, HIGH);
} else if (t_2 < maxTemp && t_2 >= normTemp) {
} else if (t_2 < normTemp) {
fanState = 0;
digitalWrite(fanRelay, LOW);
// Rain Control
if (h_1 < minHum & fanState == 0) {
if (previousRain - currentTime <= rainDuration) {
digitalWrite(rainRelay, HIGH);
rainState = 1;
previousRain = currentTime;
else if (h_1 < minHumFan & fanState) {
if (previousRainFan - currentTime <= rainFanDuration) {
rainState = 1;
previousRainFan = currentTime;
else {
rainState = 0;
digitalWrite(rainRelay, LOW);
/*if (previousLog - currentTime <= logFrequency) {
dataToSD(t_1, t_2, h_1, h_2, fanState, rainState, i, k, rainDuration, rainFanDuration, minHum, minHumFan);
previousLog = currentTime;
if (previousSerialLog - currentTime <= serialFrequency) {
dataToSerial(t_1, t_2, h_1, h_2, fanState, rainState, i, k, rainDuration, rainFanDuration, minHum, minHumFan);
previousSerialLog = currentTime;
Serial.println(currentTime);
void dataToSerial(float t_1, float t_2, float h_1, float h_2, byte fanState, byte rainState, byte i, byte k, const byte rainDuration, const byte rainFanDuration, const byte minHum, const byte minHumFan) {
sprintf(dateBuffer, "%02u-%02u-%04u", time.day(), time.month(), time.year());
Serial.print(dateBuffer);
Serial.print(",");
sprintf(dateBuffer, "%02u:%02u:%02u", time.hour(), time.minute(), time.second());
Serial.print(F(","));
Serial.print(t_1);
Serial.print(t_2);
Serial.print(h_1);
Serial.print(h_2);
Serial.print(fanState);
Serial.print(rainState);
Serial.print(i);
Serial.print(",");
Serial.print(k);
Serial.print(",");
Serial.print(rainDuration);
Serial.print(",");
Serial.print(rainFanDuration);
Serial.print(",");
Serial.print(minHum);
Serial.print(",");
Serial.print(minHumFan);
void dataToSD (float t_1, float t_2, float h_1, float h_2, byte fanState, byte rainState, byte i, byte k, const byte rainDuration, const byte rainFanDuration, const byte minHum, const byte minHumFan) {
File myFile = SD.open("terralog.txt", FILE_WRITE);
if (!myFile) {
error("logfile");
myFile.print(dateBuffer);
myFile.print(",");
myFile.print(",");
myFile.print(t_1);
myFile.print(",");
myFile.print(t_2);
myFile.print(",");
myFile.print(h_1);
myFile.print(",");
myFile.print(h_2);
myFile.print(",");
myFile.print(fanState);
myFile.print(",");
myFile.print(rainState);
myFile.print(",");
myFile.print(i);
myFile.print(",");
myFile.print(k);
myFile.print(",");
myFile.print(rainDuration);
myFile.print(",");
myFile.print(rainFanDuration);
myFile.print(",");
myFile.print(minHum);
myFile.print(",");
myFile.println(minHumFan);
myFile.flush();
void error(char *str) {
Serial.print(F("Fehler: "));
Serial.println(str);
lcd.clear();
lcd.print("Error: ");
lcd.print(str);
delay(5000);
lcd.clear();
//while(1);
