Custom made Library Issues!
Hey fellas! I am Trying to get my own library to work.. But I just can't get it to compile!
I am controlling a motor using 3 relays, I don't need help with my circuit. Just Coding issues!
Here is my library.cpp File
  Gearmotor-Driver.cpp - Library for moving a motor in two directions with relays.
  Created by micahthetanker, April 26, 2021.
  Still WIP.
#include "Arduino.h"
#include "Gearmotor-Driver.h"
Motor::ForwardsPin(FP)
  pinMode(FP, OUTPUT);
   _FP = FP;
Motor::BackwardsPin(BP);
  pinMode(BP, OUTPUT);
  _BP = BP;
Motor::On/OffPin(O/FP);
  _O/FP = O/FP;
void Motor::Forward()
  digitalWrite(FP, HIGH);
  digitalWrite(BP, HIGH);
  digitalWrite(O/FP, HIGH);
void Motor::Backward()
  digitalWrite(FP, LOW);
  digitalWrite(BP, LOW);
void Motor::Stop()
  digitalWrite(O/FP, LOW);
And here is my Library.H file
  Gearmotor-Driver.h - Library for moving a motor in two directions with relays.
  Still WIP.
#ifndef Gearmotor-Driver_h
#define Gearmotor-Driver_h
class Motor
  public:
    int O/FP;
    int BP;
    int FP;
    ForwardsPin(FP);
    BackwardsPin(BP);
    On/OffPin(O/FP);
    void Forward();
    void Backward();
    void On/Off();
  private:
    int _BP;
    int _FP;
    int _O/FP;
#endif`
and here is how I used the code
#include <Gearmotor-Driver.h>
Motor ForwardsPin(11);
Motor BackwardsPin(10);
Motor On/OffPin(9);
  Motor.Forward();
  Motor.Stop();
  Motor.Backward();
  Motor.Stop();
and here is the error I get...
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
In file included from C:\Users\micahthetanker\Documents\Arduino\Test\Test.ino:1:0:
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:6:18: warning: extra tokens at end of #ifndef directive
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:7:18: warning: ISO C++11 requires whitespace after the macro name
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:14:9: error: expected ';' at end of member declaration
     int O/FP;
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:14:10: error: expected unqualified-id before '/' token
     int O/FP;
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:17:17: error: 'FP' is not a type
     ForwardsPin(FP);
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:17:19: warning: ISO C++ forbids declaration of 'ForwardsPin' with no type [-fpermissive]
     ForwardsPin(FP);
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:18:18: error: 'BP' is not a type
     BackwardsPin(BP);
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:18:20: warning: ISO C++ forbids declaration of 'BackwardsPin' with no type [-fpermissive]
     BackwardsPin(BP);
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:19:5: error: 'On' does not name a type
     On/OffPin(O/FP);
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:22:10: error: variable or field 'On' declared void
     void On/Off();
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:22:10: error: expected ';' at end of member declaration
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:22:12: error: expected unqualified-id before '/' token
     void On/Off();
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:26:9: error: expected ';' at end of member declaration
     int _O/FP;
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:26:11: error: expected unqualified-id before '/' token
     int _O/FP;
Test:2:21: error: no matching function for call to 'Motor::Motor(int)'
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:11:7: note: candidate: Motor::Motor()
 class Motor
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:11:7: note:   candidate expects 0 arguments, 1 provided
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:11:7: note: candidate: constexpr Motor::Motor(const Motor&)
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:11:7: note:   no known conversion for argument 1 from 'int' to 'const Motor&'
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:11:7: note: candidate: constexpr Motor::Motor(Motor&&)
C:\Users\micahthetanker\Documents\Arduino\libraries\Gearmotor-Driver-0.0.1/Gearmotor-Driver.h:11:7: note:   no known conversion for argument 1 from 'int' to 'Motor&&'
Test:3:22: error: no matching function for call to 'Motor::Motor(int)'
 class Motor
Test:4:9: error: expected initializer before '/' token
 Motor On/OffPin(9);
C:\Users\micahthetanker\Documents\Arduino\Test\Test.ino: In function 'void loop()':
Test:13:8: error: expected unqualified-id before '.' token
   Motor.Forward();
Test:15:8: error: expected unqualified-id before '.' token
   Motor.Stop();
Test:17:8: error: expected unqualified-id before '.' token
   Motor.Backward();
Test:19:8: error: expected unqualified-id before '.' token
   Motor.Stop();
exit status 1
option enabled in File -> Preferences.
I just can't Figure it out!!
I have a feeling its one small mistake.. like a single character..
But no luck..
Thanks in advance!
` Gearmotor-Driver_h`
You may find that the thingy thinks you are trying to subtract Driver_h from Gearmotor.
Again, illegal characters in a variable name.
Take a look at this :slightly_smiling_face: :upside_down_face:
Here's trouble I see over and over..
Motor::On/OffPin(O/FP); // <<< ----- semicolon in wrong place for function!
  _O/FP = O/FP;
-jim lee
Just a style note.. (I) tend to put the things Mrs user needs to use at the top. Then shove all the other bits toward the end. With the protected & private stuff at the bottom.
-jim lee
