Hi community, I have a few questions about a custom PCB I'm designing. It has the ATMega32U4 MCU onboard and I had planned on purchasing chips pre-loaded with the Leonardo bootloader to avoid the need for ICSP pins on my PCB, to save board real estate.
Questions:
I'm actually using the ProMicro bootloader in development. Are the pin assignments the same as the Leonardo?
If not, then I need to program the ProMicro bootloader in. Can this be done via USB alone? I also want to eventually set the appropriate fuses later so the user code cannot be over-written.
For these reasons, must I provide ICSP connections in my design or can the tasks above be achived solely over USB? As stated I am just trying to reserve PCB space. But if ICSP is absolutely a must then I'll find a way.
Any advice much appreciated !
