I am developing a custom board based on the Renesas RA4M1 microcontroller, designed to be functionally equivalent to the Arduino UNO R4 Minima.
I would like to achieve full compatibility with the Arduino IDE, allowing users to program the board exactly as they would with an official UNO R4 Minima. To do that, I would like to know:
1. Bootloader – How can I obtain or build the official UNO R4 Minima bootloader for the RA4M1 so that my custom board can be recognized and programmed via the Arduino IDE?
* Is the bootloader open source or available for licensed use?
* What is the recommended process for flashing it onto a new RA4M1 chip?
Hi! Thanks for the link.
I'm new to bootloaders and to the RA4M1, so could you please explain step-by-step how to actually bootload my UNO R4 Minima using the files from that GitHub repository?
Specifically, I’m unsure about:
How to build the bootloader from the GitHub source
Which tools I need (e2 studio? Flash Programmer?)
How to put the board into bootloader/DFU mode
Which file I’m supposed to flash (.hex or .bin?)
How to flash it correctly onto the RA4M1
A simple, beginner-friendly walkthrough of the entire bootloading process would be very helpful.
Thanks!
Hello there. I was able to follow this document right here and flash the bootloader. The relevant parts for you are “bootloaders/UNO_R4“ and “How to load bootloader (UNO R4 Minima)”. The rfp-cli can be found in Renesas website. It works great and it’s super-fast. That said, they require a registration and they want quite some of your data - probably because of export controls. With the above, you will be able to burn the Arduino Bootloader for RA4M1 and use bossac.
