Customized Arduino Zero Board
I am working on a customized Arduino Zero Board. In my hardware, there are only four SERCOM(Serial ports) present.
  1. Serial0 - Right Motor (UART)
  2. Serial2 - LoRa Radio (UART)
  3. Serial4 - Left Motor (UART)
  4. Serial5 - EDGB Debugger Arduino Zero
Rest two has been removed. The goal of my application is to interface a GPS sensor to the board. (UART/I2C communication).
Is it possible to connect the GPS sensor to Serial5 pins even though it is reserved for EDGB Debugger?
I am flashing the code on the board using SerialUSB port currently.
Thank you
