(sorry for my english, I use a translator)
Hello everyone. I have a question about the code because I have the web server code shown below and I don't know how to change the code to control 2 or 3 pins with one button?
Previously I used BLYNK and I changed the code so that I could turn on 3 pins with one button:
BLYNK_WRITE(V0){
int value = param.asInt();
value ? digitalWrite(D1, HIGH) : digitalWrite(D1, LOW);
value ? digitalWrite(D0, HIGH) : digitalWrite(D0, LOW); //zwykla
value ? digitalWrite(D5, HIGH) : digitalWrite(D5, LOW); //zwykla
However, in this case I don't know how to do it because honestly I have no idea about it.
I tried copying and pasting some lines after the comma, but it ended with an error in the code. Maybe you write such codes with your eyes closed, but unfortunately I can't...
with control via several pins, I need LEDs because I can't connect e.g. 5-7 LEDs because they don't have that much power. so I have to split it into several pins. Therefore, I need to change the code so that when the button is turned on, it will turn on 2 or 3 (or maybe more) pins:
and this is the code we wanted to modify:
//192.168.4.1
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
/* Put your SSID & Password */
const char* ssid = "Name"; // Enter SSID here
const char* password = "Password"; //Enter Password here
ESP8266WebServer server(80);
uint8_t Relay1 = D0;
uint8_t Relay2 = D1;
uint8_t Relay3 = D2;
uint8_t Relay4 = D3;
int load1, load2, load3, load4;
pinMode(Relay1, OUTPUT);
pinMode(Relay2, OUTPUT);
pinMode(Relay3, OUTPUT);
pinMode(Relay4, OUTPUT);
EEPROM.begin(512);
load1 = EEPROM.read(1);
load2 = EEPROM.read(2);
load3 = EEPROM.read(3);
load4 = EEPROM.read(4);
Serial.print(load1); Serial.print(" ");
Serial.print(load2); Serial.print(" ");
Serial.print(load3); Serial.print(" ");
Serial.println(load4);
digitalWrite(Relay1, load1);
digitalWrite(Relay2, load2);
digitalWrite(Relay3, load3);
digitalWrite(Relay4, load4);
WiFi.softAP(ssid, password);
IPAddress apip = WiFi.softAPIP();
Serial.print("visit: \n");
Serial.println(apip);
delay(100);
server.on("/", handle_OnConnect);
server.on("/L1on", handle_L1on);
server.on("/L1off", handle_L1off);
server.on("/L2on", handle_L2on);
server.on("/L2off", handle_L2off);
server.on("/L3on", handle_L3on);
server.on("/L3off", handle_L3off);
server.on("/L4on", handle_L4on);
server.on("/L4off", handle_L4off);
server.onNotFound(handle_NotFound);
server.begin();
Serial.println("HTTP server started");
server.handleClient();
void handle_OnConnect() {
server.send(200, "text/html", SendHTML(load1,load2,load3,load4));
void handle_L1on() {load1=0;data();}
void handle_L1off() {load1=1;data();}
void handle_L2on() {load2=0;data();}
void handle_L2off() {load2=1;data();}
void handle_L3on() {load3=0;data();}
void handle_L3off() {load3=1;data();}
void handle_L4on() {load4=0;data();}
void handle_L4off() {load4=1;data();}
void data(){
EEPROM.write(1, load1);
EEPROM.write(2, load2);
EEPROM.write(3, load3);
EEPROM.write(4, load4);
EEPROM.commit();
void handle_NotFound(){
server.send(404, "text/plain", "Not found");
String SendHTML(uint8_t l1stat,uint8_t l2stat,uint8_t l3stat,uint8_t l4stat){
String ptr = "<!DOCTYPE html> <html>\n";
ptr +="<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=no\">\n";
ptr +="<title>4Load Control</title>\n";
ptr +="<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}\n";
ptr +="body{margin-top: 50px;} h1 {color: #444444;margin: 50px auto 30px;} h3 {color: #444444;margin-bottom: 50px;}\n";
ptr +=".button {display: block;width: 80px;background-color: #1abc9c;border: none;color: white;padding: 13px 30px;text-decoration: none;font-size: 25px;margin: 0px auto 35px;cursor: pointer;border-radius: 4px;}\n";
ptr +=".button-on {background-color: #1abc9c;}\n";
ptr +=".button-on:active {background-color: #16a085;}\n";
ptr +=".button-off {background-color: #34495e;}\n";
ptr +=".button-off:active {background-color: #2c3e50;}\n";
ptr +="p {font-size: 14px;color: #888;margin-bottom: 10px;}\n";
ptr +="</style>\n";
ptr +="</head>\n";
ptr +="<body>\n";
ptr +="<h2>Wifi based Home Appliance Control</h2>\n";
if(l1stat==0)
{ptr +="<p>Load1 Status: ON</p><a class=\"button button-off\" href=\"/L1off\">OFF</a>\n";}
{ptr +="<p>Load1 Status: OFF</p><a class=\"button button-on\" href=\"/L1on\">ON</a>\n";}
if(l2stat==0)
{ptr +="<p>Load2 Status: ON</p><a class=\"button button-off\" href=\"/L2off\">OFF</a>\n";}
{ptr +="<p>Load2 Status: OFF</p><a class=\"button button-on\" href=\"/L2on\">ON</a>\n";}
if(l3stat==0)
{ptr +="<p>Load3 Status: ON</p><a class=\"button button-off\" href=\"/L3off\">OFF</a>\n";}
{ptr +="<p>Load3 Status: OFF</p><a class=\"button button-on\" href=\"/L3on\">ON</a>\n";}
if(l4stat==0)
{ptr +="<p>Load4 Status: ON</p><a class=\"button button-off\" href=\"/L4off\">OFF</a>\n";}
{ptr +="<p>Load4 Status: OFF</p><a class=\"button button-on\" href=\"/L4on\">ON</a>\n";}
ptr +="</body>\n";
ptr +="</html>\n";
return ptr;
