hej,
some how i fixed a code to daisychain multiple max7219, have a look, it is working some how but there still some buggs, some times some max7219 just die, and i never just more then 4 max7219, at the end with 2 max7219 it works with out any problems so maybe i got some elektronic based problems,
please wirte a post or a mail if you noticed some mistakes in the code
/* code for max 7219 from maxim,
reduced and optimised for useing more then one 7219 in a row,
______________________________________
Code History:
The orginal Code where written for the wiring board by:
* Nicholas Zambetti and Dave Mellis
* Interaction Design Institute Ivrea
* Dec 2004
* http://www.potemkin.org/uploads/Wiring/MAX7219.txt
The first modification did:
* Marcus Hannerstig
* 2006
* K3, malmö högskola
* http://www.xlab.se | http://arduino.berlios.de
This Version is modified by:
* tomek ness
* Jan 2007
* FH-Potsdam
* http://design.fh-potsdam.de
-befor sending data make shure that the load is HIGH,
-fill all the max7219 with data. (begin with the last one)
-set the load to LOW and to HIGH again, so you will upload the data
* take care with the initiation you have to send every part to every max7219 and then upload it.
so for example if you have 5 max7219, you have to send the scanLimit 5 times befor you load it,
other wise not every max7219 will get the shit. maxInUse is keeping track of this,
just tell him how many max7219 you are uesing
int dataIn = 2;
int load = 3;
int clock = 4;
int i = 0; // just a varialble
int e = 0; // just a varialble
int f = 0;
int c = 0;
int c2= 0;
int maxInUse = 4; //here you have to change this varialbe to how many max 7219 you want to use
// define max7219 registers
byte max7219_reg_noop = 0x00;
byte max7219_reg_digit0 = 0x01;
byte max7219_reg_digit1 = 0x02;
byte max7219_reg_digit2 = 0x03;
byte max7219_reg_digit3 = 0x04;
byte max7219_reg_digit4 = 0x05;
byte max7219_reg_digit5 = 0x06;
byte max7219_reg_digit6 = 0x08;
byte max7219_reg_digit7 = 0x01;
byte max7219_reg_decodeMode = 0x09;
byte max7219_reg_intensity = 0x0a;
byte max7219_reg_scanLimit = 0x0b;
byte max7219_reg_shutdown = 0x0c;
byte max7219_reg_displayTest = 0x0f;
void putByte(byte data) {
byte i = 8;
byte mask;
while(i > 0) {
mask = 0x01 << (i - 1); // get bitmask
digitalWrite( clock, LOW); // tick
if (data & mask){ // choose bit
digitalWrite(dataIn, HIGH); // send 1
}else{
digitalWrite(dataIn, LOW); // send 0
digitalWrite(clock, HIGH); // tock
--i; // move to lesser bit
void maxPut (byte reg, byte col) { // use this
//data = ((data & 0x01) * 256) + data1 >> 1;
//data = (data << 1) + ((data >> 7) & 0x01);
putByte(reg); // specify register
putByte(col);//((data & 0x01) * 256) + data >> 1); // put data
void maxIni (byte reg, byte col) { // put the initialisation to all the max 7219 in the system
int c = 0;
digitalWrite(load, HIGH);
for ( c =1; c<= maxInUse; c++) {
maxPut(reg, col); // use all 8 columns
digitalWrite(load, LOW);
digitalWrite(load,HIGH);
void setup () {
pinMode(dataIn, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(load, OUTPUT);
beginSerial(9600);
digitalWrite(13, HIGH);
//////////////////////////////////////////////initiation of the max 7219
maxIni(max7219_reg_scanLimit, 0x07);
maxIni(max7219_reg_decodeMode, 0x00); // using an led matrix (not digits)
maxIni(max7219_reg_shutdown, 0x01); // not in shutdown mode
maxIni(max7219_reg_displayTest, 0x00); // no display test
for (i=1; i<=8; i++) { // empty registers, turn all LEDs off
maxIni(i,0);
maxIni(max7219_reg_intensity, 0x0f & 0x0f); // the first 0x0f is the value you can set
void loop () {
//------------------------------------all doing the same: 3 led on and more
printString("los");
for (i=1; i<=8; i++) { // all max7219 doing the same shit (fill up led by led at every max7219 at the same time)
//c = 1;
//for (e=1; e<=8; e++) {
maxPut(i, 193); //56, 192 is working
maxPut(i, 193); //60, 57 not
maxPut(i, 193);
maxPut(i, 193);
//delay(1);
delay(200);
delay(2000);
for (i=1; i<=8; i++) { // a longer way to clean the dispaly
maxPut(i, 0);
maxPut(i, 0);
maxPut(i, 0);
maxPut(i, 0);
//delay(1);
delay(200);
delay(2000);
