Team,
I am getting what appears to be data corruption over an XBee serial link. This is my setup...
1 - Transmitter: I am using a DF Gamepad which is based on a Leonardo board. Plugged into it is an XBee series 2, configured as a router in transparent mode running at 9600 baud.
2 - Receiver: A Makeblock Orion board, for all intents and purposes, an Uno board. With an Xbee series 2, configured as a controller in transparent mode running at 9600.
Here's my transmitter code, please note:
1 - it's sending a series of bytes
2 - the data is encapsulated with 254 at the beginning and 255 at the end.
3 - all the bytes are shaped to be no more than 250 (I've mapped the range of the analog value to site between 0-250.
int buttonState[17];
int joystick[4];
int AnalogButton[2];
unsigned char gamePadButtons[22];
int inputCommand = 0;
#define shackMotorPin 2
Serial1.begin(9600); //Init the Serial baudrate
InitIO(); // Initialize the inputs/outputs and the buffers
void InitIO(){
for(int i = 0; i < 17; i++)
pinMode(i, INPUT);
pinMode(shackMotorPin,OUTPUT);
digitalWrite(shackMotorPin,LOW); // Stop shacking of the gamepad
unsigned long timer = 0;
if(millis() - timer > 500){ // manage the updating freq of all the controlling information
DataUpdate(); //read the buttons and the joysticks data
printData(); //print the datas and states
timer = millis();
// if(Serial1.available()){
// char input = Serial1.read();
// switch(input){
// case 's':
// Serial1.println("Shack");
// inputCommand = input;
// digitalWrite(shackMotorPin,HIGH);
// break;
// case 'x':
// Serial1.println("Stop");
// digitalWrite(shackMotorPin,LOW);
// break;
// default:
// break;
void DataUpdate(){
gamePadButtons[0] = 254;
gamePadButtons[1] = map (analogRead(0), 0, 1023, 0, 250); //"J2" (250 = released, 0 = pressed)
gamePadButtons[2] = map (analogRead(1), 0, 1023, 0, 250); //"J1" (250 = released, 0 = pressed)
for(int i = 3; i < 17; i++) gamePadButtons[i] = digitalRead(i); //"S2","S1","UP","LEFT","DOWN","RIGHT","1","4","2","3","RZ1","RZ2","LZ1","LZ2"
gamePadButtons[17] = map (analogRead(2), 0, 1023, 0, 250); //"RUD" (U250,D0)
gamePadButtons[18] = map (analogRead(3), 0, 1023, 0, 250); //"RLR" (L250,R0)
gamePadButtons[19] = map (analogRead(4), 0, 1023, 0, 250); //"LUD" (U250, D0)
gamePadButtons[20] = map (analogRead(5), 0, 1023, 0, 250); //"LLR" (L250, R0)
gamePadButtons[21] = 255;
void printData(){
for(int i = 0; i < sizeof(gamePadButtons); i++) Serial1.write(gamePadButtons[i]);
//for(int i = 0; i < sizeof(gamePadButtons); i++) Serial.write(gamePadButtons[i]);
//Serial.print(" ");
for(int i = 0; i < sizeof(gamePadButtons); i++) Serial.print(gamePadButtons[i]),Serial.print(" ");
Serial.println("");
delay(30); // delay added so gamepad is not transmitting continously.
Here's the function I used to receive the data (not my design, someone else on this board wrote it.
void recvBytesWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
byte startMarker = 0xFE;
byte endMarker = 0xFF;
byte rb;
while (gamePad.available() > 0 && newData == false) {
rb = gamePad.read();
if (recvInProgress == true) {
if (rb != endMarker) {
Serial.print(rb),Serial.print(" ");
receivedBytes[ndx] = rb;
ndx++;
if (ndx >= numBytes) {
ndx = numBytes - 1;
else {
receivedBytes[ndx] = '\0'; // terminate the string
numReceived = ndx; // save the number for use when printing
ndx = 0;
newData = true;
Serial.println("EndMarker");
else if (rb == startMarker) {
recvInProgress = true;
This is what the data looks like being sent out of the transmitter (gamepad)...
** **254 250 250 1 1 1 1 1 1 1 1 1 1 1 1 1 1 124 125 122 120 255 254 250 250 1 1 1 1 1 1 1 1 1 1 1 1 1 1 124 125 122 120 255 254 250 250 1 1 1 1 1 1 1 1 1 1 1 1 1 1 124 125 122 120 255 254 249 250 1 1 1 1 1 1 1 1 1 1 1 1 1 1 124 125 122 120 255 254 249 250 1 1 1 1 1 1 1 1 1 1 1 1 1 1 124 125 122 120 255 etc...** **
and this is what I'm receiving on the other end...
** **250 250 1 1 1 [color=blue]129[/color] 1 1 1 1 [color=blue]129[/color] 1 1 1 1 1 124 125 [color=blue]250[/color] 120 EndMarker 250 250 1 1 1 1 1 1 1 [color=blue]129[/color] 1 1 1 1 1 1 124 125 122 120 EndMarker 250 250 1 [color=blue]129[/color] 1 1 1 1 1 1 1 1 1 1 [color=blue]129[/color] 1 124 125 122 120 EndMarker 250 250 1 1 [color=blue]129[/color] 1 1 1 1 1 1 1 [color=blue]129[/color] 1 1 1 124 125 122 120 EndMarker 250 250 1 [color=blue]129[/color] 1 1 1 1 1 1 1 [color=blue]129[/color] 1 1 1 1 [color=red]252[/color] 125 122 120 EndMarker 250 250 1 1 [color=blue]129[/color] 1 1 1 1 1 1 1 [color=blue]129[/color] 1 1 1 124 125 122 120 EndMarker 250 250 1 1 1 1 1 1 [color=blue]129[/color] 1 1 1 1 1 1 1 124 125 122 120 EndMarker** **
The data marked blue is erroneous, but what is more telling is the data marked in red which in this example = 252, the big problem with this is the transmitter is programmed to only send data up to 250 (excluding the start and end tags).
I added a delay in the transmitter code, and have been increasing it by 10ms to see if that helps, I'm currently up to 30ms, and I see no change.
Any ideas?
regards
Michael
