Data logger and two 4051 Mux's
I am trying to find a way to separate GetAjaxData () into smaller functions that only control one input. I would like to also find a way to log the data. But I still need the inputs to be read every second, or user defined time.
Currently, the code reads two 4051 mux's through common address lines every second. I would like to have them all read separately so that if the user is only plugged into 3 of them the other's don't show random data in the logger. I am using an arduino Mega 2560 with ethernet board.
Any help is greatly appreciated!
please find code attached
current code.txt (19.9 KB)
You can't tell is there is a 'valid' signal input unless u read the post... Which means U'll read all 16.
U may want to use an array to store values and a loop to read then. (to replace 8 equal sequences)
knut_ny
I'm afraid I do not understand what you are proposing. Could you try to explain it again in a little more detail? I apologize I do not do much coding.
altered code..
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x0E, 0xCC, 0xC8 };
IPAddress ip(192,168,1, 177);
EthernetServer server(80);
int S0=11;
int S1=12;
int S2=13;
int reading[16]; //0..7 MUX1, 9..15 MUX2  THIS IS ADDED ************
String HTTP_req; //Stores the HTTP request
      // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
 pinMode(S0,OUTPUT); //s0
  pinMode(S1,OUTPUT); //s1
  pinMode(S2,OUTPUT); //s2
//   retore this part
//send the state of the switch to the web
void GetAjaxData(EthernetClient cl)
   for(byte i=0;i<8;i++)  // REWRITTEN to use an array and a loop
    digitalWrite(S0,i & 1);
    digitalWrite(S1,i & 2);
    digitalWrite(S2,i & 4);
    reading[i] = analogRead(0); //read the arduino input pin the 4051 is using
    reading[i+8] = analogRead(1); //read the arduino input pin the 4051 is using
  // if you call your inputs numbers from 0..15, also the next section goes fine into the same loop
    cl.print(F("M1Y0 :"));
    cl.println(reading[0]);
    cl.print(F("M1Y1 :"));
    cl.println(reading[1]);
    cl.print(F("M1Y2 :"));
    cl.println(reading[2]);
    cl.print(F("M1Y3 :"));
    cl.println(reading[3]);
    cl.print(F("M1Y4 :"));
    cl.println(reading[4]);
    cl.print(F("M1Y5 :"));
    cl.println(reading[5]);
    cl.print(F("M1Y6 :"));
    cl.println(reading[6]);
    cl.print(F("M1Y7 :"));
    cl.println(reading[7]);
    cl.println("
    cl.print(F("M2Y0 :"));
    cl.println(reading[8]);
    cl.print(F("M2Y1 :"));
    cl.println(reading[9]);
    cl.print(F("M2Y2 :"));
    cl.println(reading[10]);
    cl.print(F("M2Y3 :"));
    cl.println(reading[11]);
    cl.print(F("M2Y4 :"));
    cl.println(reading[12]);
    cl.print(F("M2Y5 :"));
    cl.println(reading[13]);
    cl.print(F("M2Y6 :"));
    cl.println(reading[14]);
    cl.print(F("M2Y7 :"));
    cl.println(reading[15]);
  // comments removed
Thanks knut_ny!! That works great.
