I’m saving the values of the analog ports with time stamp on the SD card; it works great.
But my index.html will not update anymore with the values as soon I write the values on the sd card. Each part for itself (updating the website - datalogger) works.
Maybe it is a wrong approach, since I’m new to Arduino Yun. Any advice/help/comment is welcome, thx.
HTML code:
<!DOCTYPE html>
<html>
<head>
<title>Optimization System</title>
<style type="text/css">
html, body {
margin:0;
padding:0;
width:100%;
height:100%;
overflow:hidden;
body {
font-family:sans-serif;
#background {
position:absolute;
width:100%;
height:100%;
z-index:1;
#scrollbereich {
position:absolute;
top:0;
left:0;
width:100%;
height:100%;
overflow:auto;
z-index:2;
#inhalt {
padding:20px 100px 30px 200px;
z-index:2;
#footer {
position:absolute;
bottom: 0;
width: 100%;
</style>
<script type="text/javascript" src="zepto.min.js"></script>
<script type="text/javascript">
function refresh() {
$('#temperatureSMU').load('/arduino/temperatureSMU');
$('#humiditySMU').load('/arduino/humiditySMU');
$('#temperatureDatarecorder').load('/arduino/temperatureDatarecorder')
$('#humidityDatarecorder').load('/arduino/humidityDatarecorder')
$('#temperatureLaser').load('/arduino/temperatureLaser')
$('#humidityLaser').load('/arduino/humidityLaser')
</script>
</head>
<body>
<div>
<img id="background" src="background.jpg" alt="" title="" />
</div>
<div id="scrollbereich">
<h1>Temperature Optimization System</h1>
<div id="inhalt">
<h1>Systemparameters</h1>
<p>Eine mögliche Variante und Fenstergröße im Browser varrieren! Hintergrund austauschbar</p>
<table width="100%" border="2" bordercolor="#0080C0" cellpadding="3" cellspacing="3">
<tr>
<td>Location</td>
<td>Temperature</td>
<td>Humidity</td>
</tr>
<tr>
<td>SMU</td>
<td><span id="temperatureSMU"></span></td>
<td><span id="humiditySMU"></span></td>
</tr>
<tr>
<td>Datarecorder</td>
<td><span id="temperatureDatarecorder"></td>
<td><span id="humidityDatarecorder"></td>
</tr>
<tr>
<td>Laser/Camera</td>
<td><span id="temperatureLaser"></td>
<td><span id="humidityLaser"></td>
</tr>
</table>
</div>
<div id="footer">
<font size="-1">Administrator Panel</font>
<a href="http://incas.local/luci/webpanel/homepage"><img src="on.png" align="middle" border="0" width="" height=""></a>
</div>
<body onload="setInterval(refresh, 500);">
</body>
</html>
Arduino Code:
#include <Bridge.h>
#include <BridgeServer.h>
#include <BridgeClient.h>
#include <FileIO.h>
// Listen to the default port 5555, the Yún webserver
// will forward there all the HTTP requests you send
BridgeServer server;
// Bridge startup
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
Bridge.begin();
digitalWrite(13, HIGH); //on-board LED as a status light to know when Bridge has started
FileSystem.begin();
while (!SerialUSB); // wait for Serial port to connect.
SerialUSB.println("Filesystem datalogger\n");
server.listenOnLocalhost();
server.begin();
SerialUSB.println("server.begin\n");
// make a string that start with a timestamp for assembling the data to log:
String dataString;
dataString += getTimeStamp();
dataString += " = ";
// read analog sensors and append to the string:
for (int analogPin = 0; analogPin < 6; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 5) {
dataString += ","; // separate the values with a comma
File dataFile = FileSystem.open("/mnt/sd/datalog.txt", FILE_APPEND);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
SerialUSB.println(dataString);
// if the file isn't open, pop up an error:
else {
SerialUSB.println("error opening datalog.txt");
delay(2000);
// Get clients coming from server
BridgeClient client = server.accept();
// There is a new client?
if (client) {
// Process request
process(client);
// Close connection and free resources.
client.stop();
delay(50); // Poll every 50ms
void process(BridgeClient client) {
// read the command
String command = client.readStringUntil('/');
command.trim();
if (command == "temperatureSMU") {
int val = analogRead(A0);
client.print(val);
if (command == "humiditySMU") {
int humiditySMU = analogRead(A1);
client.print(humiditySMU);
if (command == "temperatureDatarecorder") {
int temperatureDatarecorder = analogRead(A2);
client.print(temperatureDatarecorder);
if (command == "humidityDatarecorder") {
int humidityDatarecorder = analogRead(A3);
client.print(humidityDatarecorder);
if (command == "temperatureLaser") {
int temperatureLaser = analogRead(A4);
client.print(temperatureLaser);
if (command == "humidityLaser") {
int humidityLaser = analogRead(A5);
client.print(humidityLaser);
// This function return a string with the time stamp
String getTimeStamp() {
String result;
Process time;
// date is a command line utility to get the date and the time
// in different formats depending on the additional parameter
time.begin("date");
time.addParameter("+%D-%T"); // parameters: D for the complete date mm/dd/yy
// T for the time hh:mm:ss
time.run(); // run the command
// read the output of the command
while (time.available() > 0) {
char c = time.read();
if (c != '\n') {
result += c;
return result;
