Datasheet redbearlab blend micro 1.0
Hello,
I'm looking for the above mentionned board datasheet, does anyone knows where I can find it?
Many thanks
Jack
I'm not sure what you consider a datasheet but maybe here: GitHub - RedBearLab/Blend: Arduino-compatible boards (Blend and Blend Micro) with BLE (Atmega32u4 + nRF8001).
You can find some documents at seeedstudio:
Don't bother clicking on this link:
• ŸFind more information on http://redbearlab.com/blendmicro.
It immediately redirects to "redbear.cc/particle", a site that can't be reached.
Thanks, yes I found these pages. What I'm looking for is a description of the different pins with the electric caracteristic such as the max output current for instance.
These boards looks not being avialable any,ore and I was hoping that someone may have kept the datasheet as the one we can found on the arduino uno for instance.
Still looking.
It uses the 32U4, so that datasheet should be the main reference.
Hello,
Many thanks, correct I found it in the 32U4 specs, max output current is 40mA.
Best regardsµ
Jak
There is more to it. Check the maximum for Vcc and GND, not behind a computer but I think it's 200 mA total.
There is also a maximum per port; although I haven't seen it in the later versions, I remember 100 mA.
Thanks, I don't know, no problem for me as soon as I can go up to 40mA per pin (I need 8 pins for a bus). that should be enough.
Best regards
