Date and Time
I have an RTC on the way, and I was wondering about setting the time. Do I need to manually set the time, or is their some way I can get the current date and time from my computer's clock? I thought I've seen something like DATE and TIME...
I have an iMac w/ 10.6.
Thanks!
If you look at the library for the DS1307, there is an example Arduino sketch and a Processing sketch that will sync the RTC to your computer's clock. (You need to run both of them obviously.)
Otherwise, you'll have to programmatically do it.
OK. Thanks! Should I subtract about 3 seconds from the second value to accommodate compile and upload times?
Couple of thoughts:
  1. I would say it depends on which RTC you are using and how much accuracy you want. For example, the DS1307 loses 1-2 second a day, assuming you have a well designed oscillator.
  2. Do the seconds even matter? If you are time stamping something, knowing what the current actual time allows you to determine the stamped time.
  3. You might consider creating a serial command that resets the seconds to zero. (Or serial interface to set the clock.)
I reworked the DS1307RTC Library and posted a whole new set of sketches and libraries...
http://arduino.cc/forum/index.php/topic,51802.0.html
May it will give you a few ideas...
It has a set program, there is one to set it from PC time -- it requires the "Processing" language available free.
I use Embarcadero Delphi an Ethernet Shield and UDP to set the clock via NTP (Internet) protocol.
See if it helps.
I found where I saw DATE and TIME:
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
void setup () {
    Serial.begin(57600);
    Wire.begin();
    RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    //RTC.adjust(DateTime(__DATE__, __TIME__));
void loop () {
    DateTime now = RTC.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(' ');
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.print(" since 1970 = ");
    Serial.print(now.unixtime());
    Serial.print("s = ");
    Serial.print(now.unixtime() / 86400L);
    Serial.println("d");
    // calculate a date which is 7 days and 30 seconds into the future
    DateTime future (now.unixtime() + 7 * 86400L + 30);
    Serial.print(" now + 7d + 30s: ");
    Serial.print(future.year(), DEC);
    Serial.print('/');
    Serial.print(future.month(), DEC);
    Serial.print('/');
    Serial.print(future.day(), DEC);
    Serial.print(' ');
    Serial.print(future.hour(), DEC);
    Serial.print(':');
    Serial.print(future.minute(), DEC);
    Serial.print(':');
    Serial.print(future.second(), DEC);
    delay(3000);
I got it from here.
Notice the
line.
In the source, it looks as if it is a C++/C define.
And it works!
This code:
#include <iostream>
using namespace std;
int main() {
cout<<__DATE__<<endl;
cout<<__TIME__<<endl;
return 0;
returns
Feb 24 2011
19:20:28
So the question is... does Arduino support that? Or do I need to load entire iostream onto Arduino? :frowning:
And....
  Serial.println(__TIME__);
That works, too!
That works, too!
But that will set the clock to the compile time (and date, if you use that), every time the Arduino resets. Is that what you really want to do?
I'll only set the time upon upload. After upload I'll set a flag in the EEPROM saying that time has been set, upon next reset, don't change time. Then, to change time, I clear flag.
OK. How will you clear the flag?
The included eeprom_clear example. This will allow the RTC to have its time set. Setting the time will set the flag, "locking" the time until the flag is cleared.
If you have an ethernetshield you can also sync with a time server - Arduino Playground - DS1307OfTheLogshieldByMeansOfNTP
I don't. And if I did, this project is standalone and won't be near my arduino or computer (uses ATtiny).
Please note that both DATE and TIME are environment variables and just are accessed by the compiler when compiling the program. Represent the build date of the program. Put this little code in a program
Serial.print ("Compilated date:");
Serial.print (DATE);
Serial.print ("");
Serial.println (TIME);
and then try to open and closer several times the serial monitor while executed. You will see that always returns the same value. No use whatsoever unless runtime display the date that the program was compiled. Something like version control .. :sunglasses:
I find it much, much easier just to put in the time manually.
Here is the program I use:
#include "Wire.h"
  Wire.begin();
  // program to precisely set Chronodot
  Wire.beginTransmission(0x68); // address DS3231
  Wire.write(0x00); // select register
  Wire.write(0x30); // seconds (BCD)
  Wire.write(0x43); // minutes (BCD)
  Wire.write(0x17); // hours (BCD)
  Wire.write(0x07); // day of week (I use Mon=1 .. Sun=7)
  Wire.write(0x15); // day of month (BCD)
  Wire.write(0x09); // month (BCD)
  Wire.write(0x13); // year (BCD, two digits)
  Wire.endTransmission();
What you do is you change the numbers to show today's date, and a time maybe 1 or 2 minutes in the future. Then you compile and upload the program. When the numbers of the real time get close to (maybe 5 seconds before) the numbers you put in the program, then press the "reset" button on the Arduino, and wait a few seconds for the program to run. Then, to avoid setting the time more than once, upload a different program, such as this one:
#include <Wire.h>
  Wire.begin();
  // clear /EOSC bit
  // Sometimes necessary to ensure that the clock
  // keeps running on just battery power. Once set,
  // it shouldn't need to be reset but it's a good
  // idea to make sure.
//  Wire.beginTransmission(0x68); // address DS3231
//  Wire.write(0x0E); // select register
//  Wire.write(0b00011100); // write register bitmap, bit 7 is /EOSC
//  Wire.endTransmission();
  // send request to receive data starting at register 0
  Wire.beginTransmission(0x68); // 0x68 is DS3231 device address
  Wire.write((byte)0); // start at register 0
  Wire.requestFrom(0x68, 7); // request seven bytes (ss, mi, hr, wd, dd, mo, yy)
  while(Wire.available())
    byte ss = Wire.read(); // get seconds
    byte mi = Wire.read(); // get minutes
    byte hh = Wire.read(); // get hours
    byte wd = Wire.read();
    byte dd = Wire.read();
    byte mo = Wire.read();
    byte yr = Wire.read();
    Serial.print ("\'");
    if (yr<0x10) Serial.print("0"); Serial.print(yr,HEX); Serial.print("-");
    if (mo<0x10) Serial.print("0"); Serial.print(mo,HEX); Serial.print("-");
    if (dd<0x10) Serial.print("0"); Serial.print(dd,HEX); Serial.print("(");
    switch (wd) {
      case 1: Serial.print("Mon"); break;
      case 2: Serial.print("Tue"); break;
      case 3: Serial.print("Wed"); break;
      case 4: Serial.print("Thu"); break;
      case 5: Serial.print("Fri"); break;
      case 6: Serial.print("Sat"); break;
      case 7: Serial.print("Sun"); break;
      default: Serial.print("Bad");
    Serial.print(") ");
    if (hh<0x10) Serial.print("0"); Serial.print(hh,HEX); Serial.print(":");
    if (mi<0x10) Serial.print("0"); Serial.print(mi,HEX); Serial.print(":");
    if (ss<0x10) Serial.print("0"); Serial.print(ss,HEX); Serial.println("");
This second program will display the time on the Serial Monitor. It is a good program for making sure that your RTC is set correctly.
Here is sample code for RTC . where you change set & read RTC date & time
RTC test.zip (1.97 KB)
Here this solution
for the format of TIME it string charactor with format 00:00:00
and DATE with format Jul:21:2015
that you can change by serial communication or first setup like this
RTC.adjust(DateTime("Jul 21 2015","02:44:20"));
