Hello. I wanna calculate my DC-motors strenght and see if it's strong enough to move 5kg (a bottle with liquid in it) back and forth. I am running this
One little thing you do need to understand - the speed used to calculate power should be radians per second, not RPM. The rest is just a matter of plugging the numbers into a calculator.
As i see it you want to lift 5 kg with a radius 13 mm wheel. Lets say: 55 N x 13 mm = 715 mNm.
At stall your motor gives 1373 mNm (194.4 oz-in). Most DC motors are linear so you can draw the torque in a graph, where Y is torque and X is RPM, as a straight line from point X=0;Y=1373 to X=60;Y=0.
Y=715 will occur at 31 RPM pretty much in the middle of the graph.
Without knowing other losses this motor looks like a good candidate...
