I would like measure the current of my DC motor on the two direction( 6VDC - 400mA nominal) on the analog input arduino. The goal is to stop the motor when the torque is too high . I don't want to use a R shunt because the consomption is too high and don't use a hall effect sensor because is not appropriate for low current .
The issue is that my system is autonomious. If if add the power lost in the shunt I devide the autonomy time by 2. One more information , it's not necessary that the measurement is accurate , and I want see only that the current go up and a low consomption for long time autonomy
LE_BU:
Where did you get this divide by 2? Your motor uses 2-3 watts. The current shunt will be in the 0.1 to 0.25 watt range most likely ( depends on the value chosen)
I take you appreciate you can decrease the range of an open core type hall sensor by looping the current wire multiple times through the core. I used a 75A unit to read in the range 0-1A by passing 75 turns through the core. Yes I needed fine enamelled covered wire but it did the job and gave low current resolution.
Alternatively in-circuit hall sensors have extremely low voltage drop and hence wattage loss
Well you're stuck aren't you? If you exclude the two workable methods to measure current there's not much left...
Remember the wiring to the motor itself forms a current shunt, you can add a sense wires at either end
and use that. Try to avoid using a shunt on the PWM'd side of the motor, very noisy and you
will then need careful attention to symmetrical differential signal routing.
