DC3231RTC with LCD and Ardiuno UNO for CLOCK!
Hello!
I want to use display time on LCD. Can you suggest codes that I can use? I have code for using RTC but I don't know how to combine them. When I tried to display seconds from the DC3231 it gives error.
Arduino: 1.6.12 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\SALAMA~1\AppData\Local\Temp\untitled856238954.tmp\sketch_oct18a\sketch_oct18a.ino: In function 'void loop()':
sketch_oct18a:135: error: 'lcd' was not declared in this scope
lcd.clear();
exit status 1
Invalid library found in C:\Users\Salamat B\Documents\Arduino\libraries_RTCtime: C:\Users\Salamat B\Documents\Arduino\libraries_RTCtime
option enabled in File -> Preferences.
This post would have more information with
some code posted between code tags.
So, where IS the code?
this should do the job
Here's one I made:
http://forum.arduino.cc/index.php?topic=408565.msg2823857#msg2823857
It uses a 16x2 character LCD.
If you have two push buttons, you can use them to set the time.
