DCF77 Module stops working with when i add adafruit 7 segment display
yes, stupid me! but, it worked for a while... or was that a random luck?
also, it now behaves the same way it did with DCF module directly on MEGA, before i started using uno with superfilter
elcrni:
If you use the same power supply for both devices, you may get an "accidental" common ground connection. Otherwise luck may also have played a part.
now when i think about it, it worked while both boards were connected to tje computer, so they may have had the common ground thay way?
then i disconnected UNO from usb and hooked it up to power supply on barrel jack... and then it didnt work any more...
Trying common ground now
Many thanks,
Alek
ok, with common ground it picked up signal and synced right away. will keep restarting during the day to see if it works every time. if the common ground was the problem, i think i should give up electronics, basic basic thing
many thanks, alek
Just to report that after numerous restarts and code tune-ups, everything works like a charm! Once again, many thanks for all suggestions and help.
Cheers,
Alek
