Wenn eine RTC am Arduino steckt -> wie kommt dann die aktuelle Zeit da drauf?
Hier meine Lösung:
#include <DS3232RTC.h> // https://github.com/JChristensen/DS3232RTC
#include <TimeLib.h> // https://github.com/PaulStoffregen/Time
#include "Timezone.h" //by Jack Christensen, not included in the Arduino IDE !!!
//uncomment to set the RTC time to compiler start time after sketch upload
#define SET_TIME
//Timezone
//Central European Time (Frankfurt, Paris, Berlin)
TimeChangeRule CEST = { "CEST", Last, So, Mrz, 2, 120 }; //Central European Summer Time
TimeChangeRule CET = { "CET ", Last, So, Okt, 3, 60 }; //Central European Standard Time
Timezone TZ(CEST, CET);
TimeChangeRule *tcr; //pointer to the time change rule, use to get the TZ abbrev
#ifdef SET_TIME
bool getTime(const char *str, tmElements_t &tm) {
uint8_t Hour, Min, Sec;
if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) {
return false;
tm.Hour = Hour;
tm.Minute = Min;
tm.Second = Sec;
return true;
bool getDate(const char *str, tmElements_t &tm) {
const char *monthName[12] = {"Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"};
char Month[12];
int Day, Year;
uint8_t monthIndex;
if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) {
return false;
for (monthIndex = 0; monthIndex < 12; monthIndex++) {
if (strcmp(Month, monthName[monthIndex]) == 0) break;
if (monthIndex >= 12) return false;
tm.Day = Day;
tm.Month = monthIndex + 1;
tm.Year = CalendarYrToTm(Year);
return true;
void print_time(time_t t, bool line_break) {
char buf[24];
sprintf(buf, "%s %02d.%02d.%d %02d:%02d:%02d", dayShortStr(weekday(t)), day(t), month(t), year(t), hour(t), minute(t), second(t));
Serial.print(String(buf));
if (line_break) {
#endif
#ifdef SET_TIME
tmElements_t tm;
// get the date and time the compiler was run
if (getDate(__DATE__, tm) && getTime(__TIME__, tm)) {
Serial.print(F("Compiler start time as Strings: Time="));
Serial.print(__TIME__);
Serial.print(F(", Date="));
Serial.println(__DATE__);
Serial.print(F("Compiler start time from system: "));
print_time(makeTime(tm), true);
time_t compile_time = TZ.toUTC(makeTime(tm));
Serial.print(F("Compiler start time in UTC: "));
print_time(compile_time, true);
//add xxx sec's to compiler start time
//muss ausprobiert werden, ob nach dem Upload die RTC Zeit in UTC genau übereinstimmt
compile_time += 28;
// and configure the RTC with this info
RTC.set(compile_time);
Serial.println(F("MakeTime was set"));
time_t current_time = TZ.toLocal(RTC.get(), &tcr);
Serial.print(F("Current Middle European Time: "));
print_time(current_time, true);
setTime(current_time);
if (timeStatus() != timeSet)
Serial.println(F("Unable to sync with the RTC"));
Serial.println(F("RTC has set the system time"));
#endif
setSyncProvider(RTC.get); // the function to get the time from the RTC
//do other stuff
//get time in local Timezone
time_t local_time = TZ.toLocal(RTC.get(), &tcr);
//wenn setSyncProvider(RTC.get) gesetzt ist, geht auch
time_t local_time = TZ.toLocal(now(), &tcr);
//do other stuff
Hat jemand Verbesserungsvorschläge?
