I'd like to share an extension to the Debounce on a Pushbutton tutorial. I added check for short/long press, and use it as a separate function.
What do you guys think?
void readShortLongPress()
const uint8_t BUTTON_PIN = 2;
const unsigned long DEBOUNCE_DELAY = 50ul;
const unsigned long LONG_PRESS_LIMIT = 400ul;
// static variables are used to presere their data between function calls
static bool pressed = false;
static bool released = false;
static unsigned long pressedMillis = 0ul;
// pull-up, reversed logic needed
static uint8_t buttonState = HIGH;
static uint8_t lastButtonState = HIGH;
static unsigned long lastDebounceTime = 0ul;
// gather current state
int reading = digitalRead(BUTTON_PIN);
if (reading != lastButtonState)
lastDebounceTime = currentMillis;
if ((currentMillis - lastDebounceTime) > DEBOUNCE_DELAY )
if (reading != buttonState)
buttonState = reading;
if (buttonState == LOW)
pressed = true;
pressedMillis = currentMillis;
released = true;
// button was pressed, but not anymore
if (pressed && released)
// compare current millis with the timestamp of the last press
if ((currentMillis - pressedMillis) >= LONG_PRESS_LIMIT )
longButtonPress = true;
shortButtonPress = true;
// flip them back
pressed = false;
released = false;
lastButtonState = reading;
