please help i have 3 LED and one push button, i want to turn on and off LED with only one push button
my push button attach to pin 2
my 3 LED attach to pin 13,12,11
this is how i want to happen
when first press LED1 will be ON
when second press LED1 will OFF and LED2 will be ON
when third press LED1 remain OFF, LED2 will be OFF and finally LED3 will be on
this is what i want please i really need help.
this is my first try from example of debounce
Debounce
Each time the input pin goes from LOW to HIGH (e.g. because of a push-button
press), the output pin is toggled from LOW to HIGH or HIGH to LOW. There's
a minimum delay between toggles to debounce the circuit (i.e. to ignore
noise).
The circuit:
LED attached from pin 13 to ground
pushbutton attached from pin 2 to +5V
10K resistor attached from pin 2 to ground
Note: On most Arduino boards, there is already an LED on the board
connected to pin 13, so you don't need any extra components for this example.
created 21 November 2006
by David A. Mellis
modified 30 Aug 2011
by Limor Fried
modified 28 Dec 2012
by Mike Walters
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Debounce
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin1 = 13; // the number of the LED pin
const int ledPin2 = 12; // the number of the LED pin
const int ledPin3 = 11; // the number of the LED pin
// Variables will change:
int ledState = HIGH; // the current state of the output pin
int buttonState; // the current reading from the input pin
int lastButtonState = LOW; // the previous reading from the input pin
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
pinMode(buttonPin, INPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
// set initial LED state
digitalWrite(ledPin1, ledState);
// read the state of the switch into a local variable:
int reading = digitalRead(buttonPin);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only toggle the LED if the new button state is HIGH
if (buttonState == HIGH) {
ledState = !ledState;
// set the LED:
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
lastButtonState = reading;
digitalWrite(ledPin2, !ledState); // here i added this code but only LED1 and LED2 will be ON vice versa
It is not completely clear to me from your description what LEDs should be on and when, but I guess it is something like this:
initial state: LED1 off ; LED2 off ; LED 3 off ;
press 1: LED1 on ; LED2 off ; LED 3 off ;
press 2: LED1 off ; LED2 on ; LED 3 off ;
press 3: LED1 off ; LED2 off ; LED 3 on ;
Repeat;
In that case, uses your debounce logic to cycle a counter 0,1,2,3,0,1,2,3 etc.
and then do something like, the example for each value of counter:
State change detection (edge detection)
Often, you don't need to know the state of a digital input all the time,
but you just need to know when the input changes from one state to another.
For example, you want to know when a button goes from OFF to ON. This is called
state change detection, or edge detection.
This example shows how to detect when a button or button changes from off to on
and on to off.
The circuit:
* pushbutton attached to pin 2 from +5V
* 10K resistor attached to pin 2 from ground
* LED attached from pin 13 to ground (or use the built-in LED on
most Arduino boards)
created 27 Sep 2005
by Tom Igoe
http://www.arduino.cc/en/Tutorial/ButtonStateChange
// this constant won't change:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin1 = 13; // the pin that the LED is attached to
const int ledPin2 = 12; // added
const int ledPin3 = 11; // added
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// initialize the button pin as a input:
// initialize the LED as an output:
pinMode(ledPin2, OUTPUT); //added
pinMode(ledPin3, OUTPUT); //added
// initialize serial communication:
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
// turns on the LED every four button pushes by
// checking the modulo of the button push counter.
// the modulo function gives you the remainder of
// the division of two numbers:
//added
if (buttonPushCounter % 1 == 0) {
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
} else if (buttonPushCounter % 2 == 0) {
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, HIGH);
} else if (buttonPushCounter % 3 == 0) {
digitalWrite(ledPin3, HIGH);
}else {
And you can use the 'switch case' to manage your state handling.
'counter' is incremented each time a button press occurs.
'counter' can be reset as needed to get back to case 0:
switch (counter)
case 0:
//do something when counter equals 0, example turn on/off LEDs as needed
case 1:
//do something when counter equals 1
case 2:
//do something when counter equals 2
case 3:
//do something when counter equals 3
// etc.
default:
// if nothing else matches, do the default
// default is optional
Thank you so much all for the quick response now my problem was solve
all response very much appreciated.
here is my working code
and on to off.
The circuit:
* 10K resistor attached to pin 2 from ground >> pulldown resistor
created 27 Sep 2005
by Tom Igoe
delay(50);
//added
if (buttonPushCounter == 1) {
} else if (buttonPushCounter == 2) {
} else if (buttonPushCounter == 3) {
}else {
buttonPushCounter =0;
