I am super excited regarding the debugging feature the new IDE has. For me this is a reason to invest on arduino. This is why I purchased a nano 33 iot. But I am having some issues.
I am simply trying to "debug" the blink sketch , but I can't.
I compile/ upload the sketch to the nano, which blinks, and get 3 issues:
#1: on the top of debug window I get: No Configurations
and a launch.json file is opened with the following:
// Use IntelliSense to learn about possible attributes.
// Hover to view descriptions of existing attributes.
"version": "0.2.0",
"configurations": []
#2: In the Notifications I get: Failed to launch OpenOCD GDB Server: Timeout.
#3: In the Cortex Peripherals I get: Unable to load SVD file: Not specified
I have tried to google and search the forums and stuff but information on the debug issue is scarce to sayt the least. Additionally whatever info I got was for different configurations and above my level..
Could someone explain what could be the issue? In as simple English as possible : ) ?
Thank you community!!
Unfortunately, I don't know anything about this FT232H. It looks interesting though.
This is the SWD pinout on the Nano 33 IoT:
Most debug probes use a standardized 2x5 0.05" pitch connector. You will want a way to easily make the connections between the two. The 0.05" pitch is not friendly to jumper wires. You can get adapters like this one:
You can see the pinout of the connector is labeled on the adapter, so it's only a matter of making the connections between the board and the cable.
I have used a a 0.1" pitch 2x3 POGO adapter pressed down on the test pads on the Nano 33 IoT for making a short term connection to burn the bootloader, but for the longer term connections you would certainly want for debugging you will find that is not feasible. It would be super cool to have a jig like this, but you might decide to go with the most simple solution and just solder wires to the test points.
