system
1
Ok its a bit dificult for me to explain it, but i will try it:
I need to declar a variable which name is build out of a nromal string and an integer variable:
for example:
int number = 3;
int example // and then their should be 3 = 9;
when you need more details just ask
thanks a lot
system
2
Sorry, I don't understand what you mean.
system
3
Okay np i will try to explain you, i have a for loop in this loop:
for( int i ; i<8; i++){
i need a new variable which contains in his name the valour of i, so Exai for example: Exa1, Exa2,...
but i don't know the code for this, when not i will try it again to explain it (i'm not really good in explaining
system
4
