Decode Manchester single wire signal to serial monitor
I'm trying to use Arduino IDE Serial Plotter and Monitor to do the same job as Saleae Logic analyser.
I can see the high and low signals from an underfloor heating system protocol in the logic analyser, and it decodes the manchester signal to hex as shown below.
Is there any library I can use to do similar with Arduino? I see some libraries for manchester decoding but the are for 1-Wire or I2C etc but not sure how to do for any old signal and ground wire protocol.
0x6C.0x30.0xF8.0xFD.0xCF.0x00.0x60.0x00.0x0F.0x00.0x80.0x07.0x30.0xEC.0xDF.0xEC.0x1F.0xB6.0xFD.0xFF.0x1B.0x1B.0x00.0xD8.0x98
decoder settings:
Differential Manchester
4613 bits/s
8 bits per transfer
negative edge is binary one
least significant bit first
Hi, @rincewindy
Have you Googled;
arduino manchester decoding
Tom... :smiley: :+1: :coffee: :australia:
Thanks Tom, I have mchr3k's Manchester lib, but I'm not sure its decoding correctly for me.
#include <Manchester.h>
const int VOL_PIN = A0;
#define BUFFER_SIZE 22
uint8_t buffer[BUFFER_SIZE];
void setup(){
    Serial.begin( 9600 );
    man.setupReceive(VOL_PIN, MAN_9600);
    man.beginReceiveArray(BUFFER_SIZE, buffer);
void loop(){
    if (man.receiveComplete()) {
        uint8_t receivedSize = 0;
            //do something with the data in 'buffer' here before you start receiving to the same buffer again
        receivedSize = buffer[0];
        for (uint8_t i = 1; i < receivedSize; i++)
          Serial.write(buffer[i]);
This doesn't give me output to match the decoding in the Logic Analyser.
Some questions I have:
In LA, I need to use 4613 baud, but Ardunio only gives me (probably incorrect) output at 9600.
I only see monitor output when BUFFER_SIZE = 22. Any other size I try outputs nothing. Messages I'm reading are typically 26 bytes.
Any way to update the manchester.cpp to use 4613? I think maybe in this area, but don't understand any of it - 9600 baud uses timer scaling factor of 5.
    Timer 2 is used with a ATMega328.
    http://www.atmel.com/dyn/resources/prod_documents/doc8161.pdf page 162
    How to find the correct value: (OCRxA +1) = F_CPU / prescaler / 1953.125
    OCR2A is only 8 bit register
    TCCR2A = _BV(WGM21); // reset counter on match
    #if F_CPU == 1000000UL
      TCCR2B = _BV(CS21); // 1/8 prescaler
      OCR2A = (64 >> speedFactor) - 1;
    #elif F_CPU == 8000000UL
      TCCR2B = _BV(CS21) | _BV(CS20); // 1/32 prescaler
      OCR2A = (128 >> speedFactor) - 1;
    #elif F_CPU == 16000000UL
      TCCR2B = _BV(CS22); // 1/64 prescaler
    #else
    #error "Manchester library only supports 8mhz, 16mhz on ATMega328"
    #endif
    TIMSK2 = _BV(OCIE2A); // Turn on interrupt
    TCNT2 = 0; // Set counter to 0
