Decremental period piezo buzzer without delay
I am making a C4 prop and I want to create decremental beeps. However, I would like to do this without using delay.
  int beepDelay = 1000;
  while (beepDelay > 46) {
    Serial.println(beepDelay);
    tone(buzzerPin, 2500);
    ledRed();
    delay(100);
    ledOff();
    noTone(buzzerPin);
    delay(beepDelay);
    beepDelay -= 15;
Currently this is how I got it to work, but I really could not figure out how to do this with the millis() function.
I have avoided the built-in duration capability of the tone() function since, for example, if you wanted a 100ms long beep with 15ms gaps,
tone(buzzerPin, 2500, 100);
delay(15);
delay(15);
does not work since the program doesn't pause for the beep, so the next beep is already triggered before 115 ms passes. This has caused problems when I attempted to implement this with the millis() function as well.
Any help is greatly appreciated.
Welcome
Did you look at the Blink Without Delay example ?
Here is an example using a simple "finite state machine" : t1121651 - Wokwi Arduino and ESP32 Simulator
The trick is to dump the while loops, dump delay() entirely, use the actual loop() function as your loop, and keep track of times. I cheat a bit using timeObj library because I hate dealing with all the millis() nonsense myself.
-jim lee
Hello selimkaraca
Welcome to the worldbest forum.
Do you are able to provide a small sound example?
I might have a look into my sketch box to find an example for you.
Thanks, that looks good.
Would it be possible to do this without using loop() as my main loop though?
Hey Paul, @jimLee recreated exactly what I wanted in wokwi. You can have a listen on there.
https://wokwi.com/projects/363497028428189697
Consider
constexpr uint8_t BuzzerPins{8};
constexpr uint32_t IntervalMillis[] {15,100};
constexpr uint32_t Frequency[] {0,2500};
uint32_t previousMillis;
uint8_t selector;
void setup() {}
  if (millis()-previousMillis >= IntervalMillis[selector])
    previousMillis=millis();
    selector=selector?LOW:HIGH;
    tone(BuzzerPins,Frequency[selector]);
