What does numbers in parentheses mean when for int variable?
"const int host = (192,168,1,10);"
In this case it is IP number, but I have tried also:
"const int a=(312,545,757,1212,10,15,25);" and compilier is OK with that.
when Serial.println(a) is used, the last number is presented.
Is it array, or what exactly such a definition/declaration mean?
No, but the programmer might have intended it to be and got it wrong
It means whoever created the code probably does not know what they are doing
That is exactly what I would expect
Google "C comma operator" for an explanation or see Comma operator - Wikipedia
In the "Preferences" turn on the verbose output for the compilation.
The compiler gives a warning: "warning: left operand of comma operator has no effect [-Wunused-value]".
braces, "{", "}", ar commonly used to initialize arrays and structs.
more likely, the following was intended
byte host [] = { 192, 168, 1, 10 };
amazing. looks like this is an error in C but not C++
hum... the difference I know of is that the comma operator may be an lvalue in C++, but never in C
I don't know why const int host = (192,168,1,10);
would be an error in C if you have the parenthesis. if you don't have the parenthesis, the comma is considered as the separator for the next declaration and then it's an error.
main.c:3:18: error: initializer element is not constant
3 | const int host = (192, 168, 1, 10);
make: *** [<builtin>: main] Error 1
don't understand why this makes sense in c++. how can the thing inside the parenthesis be considered a (const) int
Working left to right:
192, 168 = 168 (a constant)
168, 1 = 1 (a constant)
1, 10 = 10 (a constant)
Post the source of the code so that we may be able to see context.
Perhaps the code came from,
I wrote this
#include <stdio.h>
int main ( int argc , char * argv[] ) {
printf("%d\n", host);
return 0 ;
and compiled with
cc main.c -o main
I only got 3 warnings
main.c:4:21: warning: expression result unused [-Wunused-value]
main.c:4:26: warning: expression result unused [-Wunused-value]
main.c:4:31: warning: expression result unused [-Wunused-value]
3 warnings generated.
which is fair since I'm not using those
running main
does print 10 as expected.
What if the declaration const int host = (192,168,1,10); was for a global variable? Does "C" allow using such a statement outside of a function?
that's what i had done
obviously the values are constants, but i didn't think a comma separated list inside parenthesis is an "expression".
while this may be legitimate, how could such a statement be used? and if it is, is it good practice?
It's not a comma-separated list. It several successive applications of the Comma Operator (which has been in the 'C' language since forever).
11 posts later we are back at post #2
but the thing between the commas doesn't make sense
What "thing"?
It compiles for an Uno with only the warnings that @J-M-L mentioned:
Serial.println(host);
It also prints the answer I stated:
10
So what doesn't "make sense"?
BTW, the result is identical using a global declaration:
So, that also "makes sense" ... at least for C++. But perhaps (as I opined) it doesn't work as a global in 'C'.
@Tibor79 Do you understand the replies ? The code is wrong and we are discussing the comma operator.
The sketch below is "valid" code. It is harder to read, and sometimes it does not make sense. Good code shows what it is doing, so this is bad code:
int a = (1,2,3,4,5); // a=5
int b,c,d;
b = (c=100,d=-100,10); // b=10, c=100, d=-100
int f;
int e = (f = b > 10 ? 1 : 2, 3); // e=3, f=2
Serial.print( "a "); Serial.println( a);
Serial.print( "b "); Serial.println( b);
Serial.print( "c "); Serial.println( c);
Serial.print( "d "); Serial.println( d);
Serial.print( "e "); Serial.println( e);
Serial.print( "f "); Serial.println( f);
void loop() {}
GCC and Clang behave differently:
moo.c
void foo(void)
const int foo_host = (192,168,1,10);
> gcc -fsyntax-only moo.c # version 11.3.0
moo.c:1:18: error: initializer element is not constant
1 | const int host = (192,168,1,10);
> clang -fsyntax-only moo.c # version 8.0.1
moo.c:1:19: warning: expression result unused [-Wunused-value]
moo.c:1:23: warning: expression result unused [-Wunused-value]
moo.c:1:27: warning: expression result unused [-Wunused-value]
moo.c:4:27: warning: expression result unused [-Wunused-value]
moo.c:4:31: warning: expression result unused [-Wunused-value]
moo.c:4:35: warning: expression result unused [-Wunused-value]
6 warnings generated.
guess it depends on the platform or version
on my Mac with -fsyntax I only get the 3 warnings on this code
#include <stdio.h>
return 0 ;
I don't know why the compiler would not agree that 10 is a constant.
It might make sense as:
const int host = IPAddress(192,168,1,10);
That would make the (192,168,1,10) an Argument List for the constructor function of the IPAddress class. If the IPAddress class then has a conversion to 'int' it would be possible to store the value in 'host'. That might work for an ESP32 or ESP8266 where an 'int' is 32 bits but not on an UNO/Nano/Mega where 'int is only 16 bits.
