Delay Before and After Buzzer Turns On or Off
Hi all,
I am working on a very simple project that when you press a button a buzzer sounds until you let go of the button.
It is working well, but there is a slight delay from when you press the button and when the buzzer sounds, and there is about 1 seconds delay from when you let go of the the button and when the buzzer stops.
Code:
  // constants won't change. They're used here to set pin numbers:
  const int buttonPin = 9;     // the number of the pushbutton pin
  int piezoPin = 8;
  // variables will change:
  int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
   tone(piezoPin, 1000);
   if (buttonState == LOW) {
  noTone (piezoPin);
Is it possible to get rid of these delays?
Thanks very much,
Zeb
OOOPS! Sorry Posted to Soon!
I uploaded the same code again and it works!
No idea why this happened, perhaps upload error?
Thanks very much,
Zeb
Yes, it is important to know how you wired your switch.
FYI
Hi all,
Thanks for the link Delta_G!
I followed this tutorial : >>>> Click Here <<<<
I reloaded the program and it now works, not sure what went wrong!
Thanks
Zeb
