Delay button
Hello,
I have a problem with LED effects, the idea is, the same button need to control 3 LEDs, once I press the botton , it changes the leds effects.
The problem is, the botton work correctly just for the first time that I start the Arduino, the next time that botton is pressed I have some delay to change the led effect, unless I keep the botton pressed a litle bit more to change the effect just with 1 touch of the botton.
Link for video:
#define ledVm     7
#define ledAm     8
#define ledVd     9
#define pinBotton  11
int counter = 0;
int statusBotPrev = LOW;
 pinMode(ledVm,     OUTPUT);
 pinMode(ledAm,     OUTPUT);
 pinMode(ledVd,     OUTPUT);
 pinMode(pinBotton, INPUT_PULLUP);
  int BottonState = !digitalRead(pinBotton);
  //Serial.print(counter);
   if( BottonState && !statusBotPrev ) counter++;
   if(counter > 3 ) counter = 1;
  if(counter == 1){
          digitalWrite(ledVm, HIGH);
          digitalWrite(ledAm, LOW);
          digitalWrite(ledVd, LOW);
          delay(200);
          digitalWrite(ledVm, LOW);
          digitalWrite(ledAm, HIGH);
          delay(200);
          digitalWrite(ledVd, HIGH);
          delay(200);
   if(counter == 2) {
          delay(200);
          delay(200);
  if (counter == 3) {
          delay(200);
          delay(200);
  statusBotPrev = BottonState;
If you want the switch to be responsive, you need to get rid of all those delay()s.
Review the BWD (blink without delay) example in the IDE and review Robin2’s great discussion on doing several things at a time.
Also study how to use ‘State Machine’ coding.
