it suffered from the same problem: it performs a subtraction before it performs a test. So a '0' is essentially passed to the call as -1, which is 64k-1, as the argument is cast to unsigned int.
Your choice is to change the code, or recast it to your own version:
#define mydelayMicroseconds(us) do {if (us) delayMicroseconds(us);} while (0)
And change all calls to delayMicroseconds to mydelayMicroseconds.
You could use a macro and be done with it.
You don't even have to change the name.
i.e.
#define delayMicroseconds(us) do { if(us) delayMicroseconds(us);} while(0)
This will work fine. It does add a slight overhead of a runtime check if us is a variable and not a constant
but then any solution that does a run time check on the delay value will have this.
The real question is if you want a delay of 1us when the delay you are asking for is 0?
And my question of curiosity is why are you asking for a delay of zero?
Is this caused by some sort calculation that results in truncation?
PeterH:
Just out of curiosity, what is the purpose of the do/while here?
It is a way to define a multi statement macro that works regardless of whether used
along side or inside other constructs such an if statement regardless of whether
braces are used.
if(xxx)
delayMicroseconds(delay);
foo(); // do other work
If you expand that out it becomes:
if(xxx)
if (delay) delayMicroseconds(delay);
This silently/unexpectedly changes what the author wanted
in that now foo(); is called if delay is zero
vs if xxx is zero, and when xxx is zero nothing happens.
For readibility here is the resulting code re-formatted
if(xxx)
if (delay)
This change would not have happened if the original code used brackets
if(xxx)
But since using brackets is not mandatory for simple statements, the
macro should still work as expected when brackets are not used since it appears to be a simple function.
The do/while essentially turns the multi-statement macro back into a simple/single statement that can work
correctly when braces are not used.
KeithRB:
Don't you need a colon in there to complete the ternary operator '?' ?
the colon is for false statement, isn't it optional?
I think a ternary can have an empty expression 1 but must have an expression 2 (the "else" part after the colon)
To flip it, remove the semi colon, and ensure the ternary expression is fully evaluated before the ! (not) in case they pass
in more than a simple variable or constant you could do
Works, but I bet it isn't as obvious to most as the do/while(0) loop.
do/while(0) is also much more flexible for future modifications.
But we still need to hear from k7michal as all his examples were attempting
to replace a zero delay with a one Us delay to see if that is really a requirement
and why a zero is being passed in to begin with .
