delayMicroseconds exits early with values > 16300 [solved]
I was having problems with timing my stepper project, and realized that the delayMicroseconds is all over the place for larger numbers. I think it should either be fixed or have documentation update to indicate the problem. I am attaching the simple test sketch so you can see the values for yourself. I am also attaching a log of the run. The values are pretty consistent from run to run. The pattern repeats and gets as small as returning after waiting for as little as 1% of the requested time. I verified this on both a nanoV3.0 atmega238 and an Arduino Mega.
Here is the test code try it for yourself.
Please let me know if there is something wrong with the test. I realize the times are quite large and could easily be converted to use the delay() function, but it was still a big head scratcher trying to figure out what went wrong when I was seriously slowing down my stepper motor for some testing and it was stepping way faster than expected because of this issue.
In the log you can see it pass through repeated plateaus of around 16K micro seconds and the start over again. The larger values never get close to the correct wait time.
My arduino version is 1.8.1 (I attached a pic of my about box).
#define pulseMicroSecondDelay 60000  // microseconds delay starting value
#define stepDown 100  // decrement this much for each test
// current delay
unsigned long delayMicroSeconds = pulseMicroSecondDelay;
  Serial.begin(9600);          // setup the interal serial port for debug messages
  Serial.println("Setup complete");
unsigned long before;   // ms before delay
unsigned long after;    // ms after dealy
unsigned long diff;     // ms difference between before and after
    //collect the timings.
    before = micros();
    delayMicroseconds(delayMicroSeconds);
    after = micros();
    diff = after - before;
    // print some diagnostics, after we have collected our stats
    Serial.print("Delay:");
    Serial.print(delayMicroSeconds);
    Serial.print(", ms before:");
    Serial.print(before);
    Serial.print(", ms after:");
    Serial.print(after);
    Serial.print(", ms diff:");
    Serial.print(diff);
    Serial.print(", percent of expected: ");
    Serial.println((diff/(delayMicroSeconds*1.0)) * 100.0, 4);
    // decrement the delay, or loop around to the top when we get <= our step value
    if (delayMicroSeconds <= stepDown ) {delayMicroSeconds = pulseMicroSecondDelay; } else { delayMicroSeconds -= stepDown; }
delayMicrosecondslog.txt (113 KB)
Arduino Version.pdf (117 KB)
The documentation
Didn't know it had that limitation, not that I use delays much.
Thanks for the quick reply. My bad for sure, but it does not hurt to have it documented again. I went straight to the Notes and Warnings section at the bottom of the page and it is not mentioned there (and probably does not need to be as it is documented in the main section above).
Do we know the technical reason for the problem?
Here is the source code for delayMicroseconds from wiring.c. Notice this line from the 16MHz section
us <<= 2; // x4 us, = 4 cycles
When the x4 multiplication take place, you are overflowing the unsigned int.
/* Delay for the given number of microseconds.  Assumes a 1, 8, 12, 16, 20 or 24 MHz clock. */
void delayMicroseconds(unsigned int us)
	// call = 4 cycles + 2 to 4 cycles to init us(2 for constant delay, 4 for variable)
	// calling avrlib's delay_us() function with low values (e.g. 1 or
	// 2 microseconds) gives delays longer than desired.
	//delay_us(us);
#if F_CPU >= 24000000L
	// for the 24 MHz clock for the aventurous ones, trying to overclock
	// zero delay fix
	if (!us) return; //  = 3 cycles, (4 when true)
	// the following loop takes a 1/6 of a microsecond (4 cycles)
	// per iteration, so execute it six times for each microsecond of
	// delay requested.
	us *= 6; // x6 us, = 7 cycles
	// account for the time taken in the preceeding commands.
	// we just burned 22 (24) cycles above, remove 5, (5*4=20)
	// us is at least 6 so we can substract 5
	us -= 5; //=2 cycles
#elif F_CPU >= 20000000L
	// for the 20 MHz clock on rare Arduino boards
	// for a one-microsecond delay, simply return.  the overhead
	// of the function call takes 18 (20) cycles, which is 1us
	__asm__ __volatile__ (
		"nop" "\n\t"
		"nop" "\n\t"
		"nop" "\n\t"
		"nop"); //just waiting 4 cycles
	if (us <= 1) return; //  = 3 cycles, (4 when true)
	// the following loop takes a 1/5 of a microsecond (4 cycles)
	// per iteration, so execute it five times for each microsecond of
	// delay requested.
	us = (us << 2) + us; // x5 us, = 7 cycles
	// we just burned 26 (28) cycles above, remove 7, (7*4=28)
	// us is at least 10 so we can substract 7
	us -= 7; // 2 cycles
#elif F_CPU >= 16000000L
	// for the 16 MHz clock on most Arduino boards
	// of the function call takes 14 (16) cycles, which is 1us
	// the following loop takes 1/4 of a microsecond (4 cycles)
	// per iteration, so execute it four times for each microsecond of
	// delay requested.
	// we just burned 19 (21) cycles above, remove 5, (5*4=20)
	// us is at least 8 so we can substract 5
	us -= 5; // = 2 cycles,
#elif F_CPU >= 12000000L
	// for the 12 MHz clock if somebody is working with USB
	// for a 1 microsecond delay, simply return.  the overhead
	// of the function call takes 14 (16) cycles, which is 1.5us
	// the following loop takes 1/3 of a microsecond (4 cycles)
	// per iteration, so execute it three times for each microsecond of
	// delay requested.
	us = (us << 1) + us; // x3 us, = 5 cycles
	// we just burned 20 (22) cycles above, remove 5, (5*4=20)
	us -= 5; //2 cycles
#elif F_CPU >= 8000000L
	// for the 8 MHz internal clock
	// for a 1 and 2 microsecond delay, simply return.  the overhead
	// of the function call takes 14 (16) cycles, which is 2us
	if (us <= 2) return; //  = 3 cycles, (4 when true)
	// the following loop takes 1/2 of a microsecond (4 cycles)
	// per iteration, so execute it twice for each microsecond of
	// delay requested.
	us <<= 1; //x2 us, = 2 cycles
	// we just burned 17 (19) cycles above, remove 4, (4*4=16)
	// us is at least 6 so we can substract 4
	us -= 4; // = 2 cycles
#else
	// for the 1 MHz internal clock (default settings for common Atmega microcontrollers)
	// the overhead of the function calls is 14 (16) cycles
	if (us <= 16) return; //= 3 cycles, (4 when true)
	if (us <= 25) return; //= 3 cycles, (4 when true), (must be at least 25 if we want to substract 22)
	// compensate for the time taken by the preceeding and next commands (about 22 cycles)
	us -= 22; // = 2 cycles
	// the following loop takes 4 microseconds (4 cycles)
	// per iteration, so execute it us/4 times
	// us is at least 4, divided by 4 gives us 1 (no zero delay bug)
	us >>= 2; // us div 4, = 4 cycles
#endif
	// busy wait
		"1: sbiw %0,1" "\n\t" // 2 cycles
		"brne 1b" : "=w" (us) : "0" (us) // 2 cycles
	// return = 4 cycles
The issue is the way/type of variable used within the delayMicroseconds() library code.
While delayMs() will do what you want right now - learn about micros() and millis() for all timing.
