Delays and TimerOne
So I'm trying to make a traffic light intersection with two green LEDs, two yellow LEDs, and two red LEDs. I also have a piezo speaker (buzzer) and a push button. I want the traffic lights to run normally and if the push button is pressed, I want the piezo to buzz, the lights to turn red, the lights to STAY red for 3 seconds, and to return to loop after all of that. I'm also using the Arduino TimerOne library.
Now the problem is that I can't get the lights to stay red for 3 seconds. My question is "how can I get my lights to stay red for 3 seconds?".
Here's my code:
#include "TimerOne.h" /* includes TimerOne library */
int red1 = 4; /* Red LED (for North-South road) connected to Digital pin 4 */
int yellow1 = 3; /* Yellow LED (for North-South road) connected to Digital pin 3 */
int green1 = 9; /* Green LED (for North-South road) connected to Digital pin 9 */
int red2 = 5; /* Red LED (for East-West road) connected to Digital pin 5 */
int yellow2 = 6; /* Yellow LED (for East-West road) connected to Digital pin 6 */
int green2 = 7; /* Green LED (for East-West road) connected to Digital pin 7 */
int g1r2delayTime = 5000; /* stores Delay for when North-South lights are GREEN & East-West lights are RED */
int y1r2delayTime = 3000; /* stores Delay for when North-South lights are YELLOW & East-West lights are Red */
int r1r2delayTime = 1000; /* stores Delay for when North-South lights are RED & East-West lights are RED */
int r1g2delayTime = 5000; /* stores Delay for when North-South lights are RED & East-West lights are GREEN */
int r1y2delayTime = 1000; /* stores Delay for when North-South lights are RED & East-West lights are YELLOW */
int alarm = 8; /* Piezo Speaker (Buzzer) connected to Digital pin 8 */
const int switch1 = 2; /* Push Button (switch1) connected to Digital pin 2 */
int switch1State = 0; /* stores Push Button (switch1) reading */
long debounceDelay = 200; /* the Debounce time is 200 milliseconds */
long lastDebounceTime = 0;
int i = 0;
int BlinkState = 0;
// digitalWrite(5, digitalRead(5) ^ 1);
void buttonPress() {
  switch1State = digitalRead(switch1); /* store the state of the Push Button in "switch1State" */
  Timer1.initialize(10); /* initializes timer1, and set a 10 millisecond period */
  Timer1.attachInterrupt(alarmSystem); /* attaches Blink() as a timer interrupt function */
  Serial.begin(9600); /* opens the Serial port at 9600 b/s */
  pinMode(red1, OUTPUT); /* initializes RED LED (for North-South road) as an ouput */
  pinMode(yellow1, OUTPUT); /* initializes YELLOW LED (for North-South road) as an output */
  pinMode(green1, OUTPUT); /* initializes GREEN LED (for North-South road) as an output */
  pinMode(red2, OUTPUT); /* initializes RED LED (for East-West road) as an ouput */
  pinMode(yellow2, OUTPUT); /* initializes YELLOW LED (for East-West road) as an output */
  pinMode(green2, OUTPUT); /* initializes GREEN LED (for East-West road) as an output */
  pinMode(alarm, OUTPUT); /* initializes Piezo Speaker (Buzzer) as an output */
  pinMode(switch1, INPUT); /* initializes Push Button as an input */
  attachInterrupt(digitalPinToInterrupt(switch1), buttonPress, CHANGE); /* if value of "switch1" changes, run function "buttonPress()" */
void BlinkStateCheck() {
  if (BlinkState == 1) {
    BlinkState = 0;
    loop();
void redlights() {
  digitalWrite(red1, HIGH); /* North-South lights are RED & East-West lights are RED */
  digitalWrite(yellow1, LOW);
  digitalWrite(green1, LOW);
  digitalWrite(red2, HIGH);
  digitalWrite(yellow2, LOW);
  digitalWrite(green2, LOW);
void alarmSystem() {
  //  switch1State = digitalRead(switch1);
  if (((millis() - lastDebounceTime) > debounceDelay) && (switch1State == HIGH)) {
    tone(alarm, 800, 1000);
    redlights();
    BlinkState = 1;
    lastDebounceTime = millis(); /* store the current time in "lastDebounceTime" */
  noTone(alarm);
  BlinkStateCheck();
  digitalWrite(red1, LOW); /* North-South lights are GREEN & East-West lights are RED */
  digitalWrite(green1, HIGH);
  delay(g1r2delayTime);
  BlinkStateCheck();
  digitalWrite(red1, LOW); /* North-South lights are YELLOW & East-West lights are RED */
  digitalWrite(yellow1, HIGH);
  delay(y1r2delayTime);
  BlinkStateCheck();
  delay(r1r2delayTime);
  /* Midway(ish) */
  BlinkStateCheck();
  digitalWrite(red1, HIGH); /* North-South lights are RED & East-West lights are GREEN */
  digitalWrite(red2, LOW);
  digitalWrite(green2, HIGH);
  delay(r1g2delayTime);
  BlinkStateCheck();
  digitalWrite(red1, HIGH); /* North-South lights are RED & East-West lights are YELLOW */
  digitalWrite(yellow2, HIGH);
  delay(r1y2delayTime);
  BlinkStateCheck();
I'm a beginner so please go easy on me. Any ideas? Thanks!
You're making it way harder than it should be.
Get rid of the timer and hardware interrupts. You don't need them.
On top of that, you have infinite recursion in your code: loop calls BlinkStateCheck and BlinkStateCheck calls loop. That will cause a stack overflow after a couple of times.
Pieter
