Well.... Now i'm getting this error message.... Was this caused by deleting those libraries? They weren't relevant to the sketch.
Arduino: 1.5.8 (Windows 8), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 4,626 bytes (1%) of program storage space. Maximum is 253,952 bytes.
Global variables use 464 bytes (5%) of dynamic memory, leaving 7,728 bytes for local variables. Maximum is 8,192 bytes.
avrdude: ser_open(): can't open device "\.\COM7": The system cannot find the file specified.
avrdude: ser_drain(): read error: The handle is invalid.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
processing.app.SerialException: Error opening serial port 'COM7'.
at processing.app.Serial.(Serial.java:145)
at processing.app.Serial.(Serial.java:90)
at processing.app.SerialMonitor.open(SerialMonitor.java:93)
at processing.app.Editor.handleSerial(Editor.java:2537)
at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:357)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: jssc.SerialPortException: Port name - COM7; Method name - openPort(); Exception type - Port not found.
at jssc.SerialPort.openPort(SerialPort.java:167)
at processing.app.Serial.(Serial.java:141)
... 35 more
enabled in File > Preferences.
