The idea is to put all the electronic [Arduino UNO+TCRT5000 IR sensor+battery+LEDs] inside of the wooden part.
I'll angle the IR upward (underneath a thin see-through acrylic surface) and program the LEDs according to the distance in-between the white floating shape and the wooden part.
The principle would be to have a variation of LED's light intensity when you make the floating shape "bouncing" with your finger (it's working with magnets, no magic : ) or I'll just make it blink ON/OFF according to the up-and-down movements.
Moreover, when the white shape is taken off from the tube, the LEDs should turn off too...
I think it's electronically not that complexe but I'm really bad for this... Like really.
I rade/watched articles and tutos but I don't get it. The more I do research, the more I dig into ampers, Arduino, resistors, ohms.. the more I lose myself.
My peers and teachers adviced me to post this on the Arduino forum which is, I hope a nice shot !
Did anyone already work with this sensor and might know how I can make it happen ? Pictures really help me.
I'm working on it (and on side projects) for weeks and I feel more and more stupid. Moreover, the deadline is soon soon...
Help !! Thanks for your attention and happy new year
Cheers and I'll show you the final outcome for sure
There's a good chance that your acrylic is not transparent to IR indeed.
Another thing: it doesn't look like an Uno is going to fit in there. Look at the Mini and the Pro Micro, a much smaller form factor, and far more suited for permanent installations like this one.
Are the LEDs going to be in the bouncy part, or in the base?
As you have a transparent tube around it, you could consider lighting up that tube as well by putting some LEDs in the base of it.
The Arduino board will go in the wooden part, which will be bigger at the end
The acrylic board will be 2mm thick, so I guess it will be ok... otherwise I'll go for a 1mm
The LEDs will be in the base, so it will indeed lighten up the acrylic tube
ben_mtc:
That it is transparent to visible light doesn't necessarily mean it's transparent to IR (and the other way around).
Some plastics are completely opaque to IR - PMMA blocks wavelengths of 2800-25000 nm, which includes a large part of IR. You'll really have to try this out. If it's blocking, 1 mm blocks just as well.
