Designing a Stepper Motor Powered Syringe Pump. Help greatly appreciated
Hi everyone, I am currently working on a project at my lab where I am trying to design a stepper motor controlled syringe pump. I recently discovered a past project that seemed quite robust and I am planning on basing my device on this past project:
http://www.mass-spec.ru/projects/diy/syringe_pump/eng/
One difference is that in the above project, the device incorporates an LCD display and button user interface which is highly integrated into their firmware.
I am trying to adjust the firmware so that I can control the syringe directly with the serial monitor. My knowledge of C++ is quite limited and I would greatly appreciate any help on how I can modify the code below:
//#include <LiquidCrystal.h>
#include <EEPROM.h>
          BASIC SETTINGS
// Stepper motor
#define NOFMICROSTEPS 16      // The number of microsteps per step
#define NOFSTEPSPER360 200    // The number of steps per revolution
#define MAXRPM 240            // Maximum RPM (rotations per minute)
#define INVERTDIRECTION true // If the carriage moves in the opposite direction, change to 'false'
// Leadscrew
#define MMPER360 2            // Leadscrew pitch, mm per revolution
// Arduino pins
#define STEP_PIN 2            // STEP pin (A4988)
#define DIRECTION_PIN 3       // DIR pin (A4988)
#define ENABLE_PIN 12         // EN pin (A4988)
#define ENDSTOP_PIN1 A1       // Endstop pin (forward movement)
#define ENDSTOP_PIN2 A2       // Endstop pin (backward movement)
//#define BUZZER_PIN 11         // Buzzer pin
//#define BUTTONS_PIN A0        // Button pin (lcd keypad shield)
//#define DEBOUNCEDELAY 50
#define LONGPRESSDELAY 450
#define AUTOCHANGINGDELAY 300
#define NITEMS 43
#define LINK2S 12
#define LINK2E 13
#define LINK2V 20
#define LINK2T 21
#define LINK2F 22
#define LINK2DIA 41
#define LINK2LPV 42
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
struct MenuItem
  uint8_t button[4];
  uint8_t type;
  char *text;
  uint8_t address;
  uint32_t value;
enum listOfButtons {RIGHT, UP, DOWN, LEFT, SELECT, NA};
enum listOfButtonStates {RELEASE, SHORTPRESS, MEDIUMPRESS, LONGPRESS};
enum listOfPrograms {CHANGEVALUE = 200, SELECTFROMLIST, INFUSEVOLUME, INFUSETIME, REFILLVOLUME, REFILLFULL, CYCLEMODE, FIRMWAREINFO};
enum listOfItemTypes {TEXT, LIST, VOLUME, TIME, FLOWRATE, LENGTHPERVOLUME, DIAMETER};
const char firmwareInfo[] = "0.9a";
const uint16_t volumeDivider[2] = {1000, 1};
const uint16_t timeDivider[3] = {1, 60, 3600};
const uint16_t flowrateDivider[4] = {60000, 1000, 60, 1};
const float stepsPERmm = NOFSTEPSPER360 / MMPER360;
MenuItem items[NITEMS];
uint8_t lastButton = NA;
uint8_t buttonState = RELEASE;
uint32_t buttonPressTime = 0;
uint8_t currentItem = 1;
float coef;
uint8_t endStopPin;
volatile uint32_t ustepCounter;
uint32_t ustepCounterLimit;
uint32_t getValue(uint8_t itemNo);
void changeValue();
void setValue(uint8_t itemNo, uint8_t digits[8]);
void selectFromList();
void calculateActualValue(uint8_t itemNo);
void recalculateSyringe(uint8_t itemNo);
void printScreen();
void printUnits();
void printFirmwareInfo();
void printTimeAndVolume(uint16_t pumpingTime, uint32_t pumpingVolume);
void showScreensaver();
void readFromEEPROM(uint8_t itemNo);
void writeToEEPROM(uint8_t itemNo);
void getButtonState();
uint16_t valueDivider (uint8_t n);
uint8_t getElementNo(uint8_t linkToList);
void waitingForButton(uint8_t buttonCode, uint8_t itemNo);
void beep (uint16_t delayOn = 15, uint16_t delayOff = 100);
bool checkEndstop(int8_t pumpingDirection);
void infuseVolume();
void infuseTime();
void refillVolume();
void refillFull();
void pumpSingly(int8_t pumpingDirection, uint32_t flowrate, uint32_t volume);
void pumpContinuously();
uint8_t pump(uint32_t flowrate, uint32_t volume);
  setup
  lcd.begin(16, 2);
  pinMode(STEP_PIN, OUTPUT);
  pinMode(DIRECTION_PIN, OUTPUT);
  pinMode(ENABLE_PIN, OUTPUT);
  pinMode(ENDSTOP_PIN1, INPUT_PULLUP);
  pinMode(ENDSTOP_PIN2, INPUT_PULLUP);
  pinMode(BUZZER_PIN, OUTPUT);
  digitalWrite(ENABLE_PIN, HIGH);
  items[1]  = {5, 0, 2, 0, TEXT, "Infuse"};
  items[2]  = {7, 1, 3, 0, TEXT, "Refill"};
  items[3]  = {9, 2, 4, 0, TEXT, "Cycle Mode"};
  items[4]  = {10, 3, 0, 0, TEXT, "Settings"};
  items[5]  = {15, 0, 6, 1, TEXT, "Target Volume"};
  items[6]  = {16, 5, 0, 1, TEXT, "Target Time"};
  items[7]  = {17, 0, 8, 2, TEXT, "Full Refill"};
  items[8]  = {18, 7, 0, 2, TEXT, "Target Volume"};
  items[9]  = {19, 0, CHANGEVALUE, 3, FLOWRATE, "infuse flow:", 1, 120000000};
  items[10] = {20, 0, 11, 4, TEXT, "Units"};
  items[11] = {23, 10, 12, 4, TEXT, "Syringe"};
  items[12] = {25, 11, 13, 4, LIST, "Sound", 2};
  items[13] = {27, 12, 14, 4, LIST, "EEPROM", 3};
  items[14] = {FIRMWAREINFO, 13, 0, 4, TEXT, "Firmware"};
  items[15] = {29, 0, CHANGEVALUE, 5, VOLUME, "volume:", 4, 1000000};
  items[16] = {30, 0, CHANGEVALUE, 6, TIME, "time:", 5, 60000};
  items[17] = {REFILLFULL, 0, CHANGEVALUE, 7, FLOWRATE, "flowrate:", 6, 2000000};
  items[18] = {31, 0, CHANGEVALUE, 8, VOLUME, "volume:", 7, 1000000};
  items[19] = {CYCLEMODE, 0, CHANGEVALUE, 9, FLOWRATE, "refill flow:", 8, 2000000};
  items[20] = {32, 0, 21, 10, LIST, "Volume Units", 9};
  items[21] = {34, 20, 22, 10, LIST, "Time Units", 10};
  items[22] = {37, 21, 0, 10, LIST, "Flowrate Units", 11};
  items[23] = {41, 0, 24, 11, TEXT, "Diameter"};
  items[24] = {42, 23, 0, 11, TEXT, "Length/Volume"};
  items[25] = {SELECTFROMLIST, 0, 26, 12, TEXT, "on"};
  items[26] = {SELECTFROMLIST, 25, 0, 12, TEXT, "off"};
  items[27] = {SELECTFROMLIST, 0, 28, 13, TEXT, "on"};
  items[28] = {SELECTFROMLIST, 27, 0, 13, TEXT, "off"};
  items[29] = {INFUSEVOLUME, 0, CHANGEVALUE, 15, FLOWRATE, "flowrate:", 12, 2000000};
  items[30] = {INFUSETIME, 0, CHANGEVALUE, 16, FLOWRATE, "flowrate:", 13, 2000000};
  items[31] = {REFILLVOLUME, 0, CHANGEVALUE, 18, FLOWRATE, "flowrate:", 14, 2000000};
  items[32] = {SELECTFROMLIST, 0, 33, 20, TEXT, "mL"};
  items[33] = {SELECTFROMLIST, 32, 0, 20, TEXT, "uL"};
  items[34] = {SELECTFROMLIST, 0, 35, 21, TEXT, "s"};
  items[35] = {SELECTFROMLIST, 34, 36, 21, TEXT, "min"};
  items[36] = {SELECTFROMLIST, 35, 0, 21, TEXT, "h"};
  items[37] = {SELECTFROMLIST, 0, 38, 22, TEXT, "mL/s"};
  items[38] = {SELECTFROMLIST, 37, 39, 22, TEXT, "mL/min"};
  items[39] = {SELECTFROMLIST, 38, 40, 22, TEXT, "uL/s"};
  items[40] = {SELECTFROMLIST, 39, 0, 22, TEXT, "uL/min"};
  items[41] = {0, 0, CHANGEVALUE, 23, DIAMETER, "diameter:", 15, 11284};
  items[42] = {0, 0, CHANGEVALUE, 24, LENGTHPERVOLUME, "length/volume:", 16, 10000};
  for (uint8_t i = 1; i < NITEMS; i++)
    if (items[i].type != TEXT) readFromEEPROM(i);
  recalculateSyringe(LINK2DIA);
  beep();
  showScreensaver();
  loop
  uint8_t nextItem;
  getButtonState();
  if (buttonState == SHORTPRESS && lastButton != SELECT)
    buttonState = MEDIUMPRESS;
    nextItem = items[currentItem].button[lastButton];
    if (nextItem != 0 && nextItem < 200)
      currentItem = nextItem;
      printScreen();
    else if (nextItem == CHANGEVALUE) changeValue();
    else if (nextItem == SELECTFROMLIST) selectFromList();
    else if (nextItem == INFUSEVOLUME) infuseVolume();
    else if (nextItem == INFUSETIME) infuseTime();
    else if (nextItem == REFILLVOLUME) refillVolume();
    else if (nextItem == REFILLFULL) refillFull();
    else if (nextItem == CYCLEMODE) pumpContinuously();
    else if (nextItem == FIRMWAREINFO) printFirmwareInfo();
  getValue
  uint16_t divider = valueDivider(items[itemNo].type);
  uint8_t lastDigitIncrement = 0;
  if ( uint16_t(items[itemNo].value % divider) > divider / 2) lastDigitIncrement = 1;
  if (items[itemNo].value / divider > 99999999)
    items[itemNo].value = divider * 99999999;
    return 99999999;
  else return (items[itemNo].value / divider) + lastDigitIncrement;
  changeValue
void changeValue()
  uint8_t digits[8];
  uint32_t value = getValue(currentItem);
  for (int8_t i = 7; i >= 0; i--)
    digits[i] = uint8_t(value % 10);
    value /= 10;
  lcd.setCursor(0, 1);
  for (int8_t i = 0; i < 4; i++) lcd.print(digits[i]);
  lcd.cursor();
  int8_t i = 0;
  while (i >= 0 && i < 8)
    getButtonState();
    if (buttonState == SHORTPRESS || buttonState == LONGPRESS)
      if (lastButton == UP) digits[i] = (digits[i] + 1) % 10;
      else if (lastButton == DOWN) digits[i] = (digits[i] + 9) % 10;
      if (lastButton == RIGHT) i++;
      else if (lastButton == LEFT) i--;
      if (i == -1 && buttonState != SHORTPRESS) i++;
      if (i == 8 && buttonState != SHORTPRESS) i--;
      if (i < 5)lcd.setCursor(i, 1);
      else lcd.setCursor(i + 1, 1);
      if (buttonState == SHORTPRESS) buttonState = MEDIUMPRESS;
      else if (buttonState == LONGPRESS)
        uint32_t nextMillis = millis() + AUTOCHANGINGDELAY;
        while (nextMillis > millis() && buttonState == LONGPRESS) getButtonState();
  if (i == 8)
    bool isSame = true;
    for (int8_t j = 7; j >= 0 && isSame == true; j--)
      if (digits[j] != uint8_t(value % 10)) isSame = false;
      value /= 10;
    bool isZero = true;
    for (int8_t j = 7; j >= 0 && isZero == true; j--)
      if (digits[j] != 0) isZero = false;
    if (isSame == false && isZero == false)
      setValue(currentItem, digits);
      beep();
  lcd.noCursor();
  printScreen();
  setValue
  uint32_t value = 0;
  for (int8_t i = 0; i < 8; i++) value = value * 10 + digits[i];
  if (4294000000 / divider < value) items[itemNo].value = 4294000000;
  else items[itemNo].value = value * divider;
  if (itemNo == LINK2LPV || itemNo == LINK2DIA)
    recalculateSyringe(itemNo);
    writeToEEPROM(LINK2LPV);
    writeToEEPROM(LINK2DIA);
  else writeToEEPROM(itemNo);
  selectFromList
  uint8_t parentItem = items[currentItem].button[LEFT];
  items[parentItem].button[RIGHT] = currentItem;
  writeToEEPROM(parentItem);
  beep();
  currentItem = parentItem;
  printScreen();
  if (items[itemNo].type == FLOWRATE)
    float maxFlowrate = 1e9 * MAXRPM * MMPER360 / (float)items[LINK2LPV].value;
    if ((float)(items[itemNo].value) > maxFlowrate) items[itemNo].value = (uint32_t)maxFlowrate;
    float ustepsPERmin = coef * NOFMICROSTEPS * (float)items[itemNo].value;
    if (ustepsPERmin < 14.4) ustepsPERmin = 14.4;
    float multiplier;
    if (ustepsPERmin >= 229) multiplier = 15000000;
    else multiplier = 937500;
    float tempFloat = multiplier / ustepsPERmin;
    uint16_t countsPERustepActual = (uint16_t)(tempFloat + 0.5);
    tempFloat = multiplier / (float)countsPERustepActual;
    tempFloat /= (float)(coef * NOFMICROSTEPS);
    items[itemNo].value = (uint32_t)tempFloat;
  else if (items[itemNo].type == VOLUME)
    uint32_t nSteps = (uint32_t)(coef * (float)items[itemNo].value + 0.5);
    float tempFloat = (float)nSteps / coef;
  else if (items[itemNo].type == TIME)
    if (items[itemNo].value > 59994000) items[itemNo].value = 59994000;
    items[itemNo].value -= (items[itemNo].value % 1000);
  recalculateSyringe
  if (itemNo == LINK2LPV)
    float temp = 1128379 / sqrt((float)items[LINK2LPV].value);
    items[LINK2DIA].value = uint32_t(temp + 0.5);
  else if (itemNo == LINK2DIA)
    float temp = 1128379 / (float)items[LINK2DIA].value;
    temp *= temp;
    items[LINK2LPV].value = uint32_t(temp + 0.5);
  coef = ((float)items[LINK2LPV].value * stepsPERmm) * 1e-9;
  printScreen
void printScreen()
  lcd.clear();
  lcd.setCursor(0, 0);
  if (items[currentItem].type == TEXT || items[currentItem].type == LIST)
    lcd.print(F("> "));
    lcd.print(items[currentItem].text);
    if (items[currentItem].button[DOWN] != 0 && items[currentItem].button[DOWN] < 200)
      lcd.print(F("  "));
      lcd.print(items[items[currentItem].button[DOWN]].text);
    calculateActualValue(currentItem);
    char outputLine[10] = "    0.000";
    for (int8_t i = 8; i >= 0 && value > 0; i--)
      if (i != 5)
        outputLine[i] = char((value % 10) + '0');
        value /= 10;
    lcd.print(outputLine);
    printUnits();
  printUnits
void printUnits()
  lcd.print(F(" "));
  if (items[currentItem].type == VOLUME) lcd.print(items[items[LINK2V].button[RIGHT]].text);
  else if (items[currentItem].type == TIME) lcd.print(items[items[LINK2T].button[RIGHT]].text);
  else if (items[currentItem].type == FLOWRATE) lcd.print(items[items[LINK2F].button[RIGHT]].text);
  else if (items[currentItem].type == LENGTHPERVOLUME)
    lcd.print(F("mm/"));
  else if (items[currentItem].type == DIAMETER) lcd.print(F("mm"));
  printFirmwareInfo
  lcd.clear();
  lcd.print(F("version:"));
  lcd.print(F("  "));
  lcd.print(firmwareInfo);
  waitingForButton(LEFT, currentItem);
  printTimeAndVolume
  char outputLine[17] = "  0:00    0000xL";
  outputLine[14] = items[items[LINK2V].button[RIGHT]].text[0];
  uint8_t pointLocation;
  if (pumpingVolume < 100000)pointLocation = 3;
  else if (pumpingVolume < 1000000)
    pointLocation = 4;
    pumpingVolume /= 10;
    pointLocation = 6;
    pumpingVolume /= 100;
  if (pointLocation < 6)outputLine[pointLocation + 8] = '.';
  uint16_t timeDivider;
  for (int8_t i = 5; i >= 0; i--)
    if (pumpingTime > 0 && i != 3)
      if (i == 4) timeDivider = 6;
      else timeDivider = 10;
      outputLine[i] = uint8_t(pumpingTime % timeDivider) + '0';
      pumpingTime /= timeDivider;
    if (pumpingVolume > 0 && i != pointLocation)
      outputLine[i + 8] = uint8_t(pumpingVolume % 10) + '0';
  showScreensaver
  lcd.clear();
  lcd.print(F("   OpenSP 0.9   "));
  lcd.print(F("www.mass-spec.ru"));
  currentItem = 1;
  waitingForButton(NA, currentItem);
  getButtonState
  uint8_t button;
  uint8_t x = analogRead(BUTTONS_PIN) / 4;
  if (x < 13) button = RIGHT;
  else if (x < 46) button = UP;
  else if (x < 84) button = DOWN;
  else if (x < 131) button = LEFT;
  else if (x < 207) button = SELECT;
  else button = NA;
  if (button == NA)
    lastButton = NA;
  else if (button != lastButton)
    lastButton = button;
    buttonPressTime = millis();
  else if (millis() - buttonPressTime > LONGPRESSDELAY) buttonState = LONGPRESS;
  else if (millis() - buttonPressTime > DEBOUNCEDELAY && buttonState == RELEASE) buttonState = SHORTPRESS;
  valueDivider
uint16_t valueDivider (uint8_t itemType)
  if (itemType == VOLUME) return volumeDivider[getElementNo(LINK2V)];
  else if (itemType == TIME) return timeDivider[getElementNo(LINK2T)];
  else if (itemType == FLOWRATE) return flowrateDivider[getElementNo(LINK2F)];
  else if (itemType == LENGTHPERVOLUME) return 1000 / volumeDivider[getElementNo(LINK2V)];
  else if (itemType == DIAMETER) return 1;
  getElementNo
  uint8_t uppermostItem = items[linkToList].button[RIGHT];
  uint8_t elementNo = 0;
  while (items[uppermostItem].button[UP] != 0)
    uppermostItem = items[uppermostItem].button[UP];
    elementNo++;
  return elementNo;
  waitingForButton
void waitingForButton(uint8_t button, uint8_t itemNo)
  if (button == NA) while (buttonState != SHORTPRESS) getButtonState();
  else while (buttonState != SHORTPRESS || lastButton != button) getButtonState();
  currentItem = itemNo;
  printScreen();
  beep
void beep (uint16_t delayOn, uint16_t delayOff)
  uint8_t daughterItem = items[LINK2S].button[RIGHT];
  if (items[daughterItem].text == "on")
    digitalWrite(BUZZER_PIN, HIGH);
    delay(delayOn);
    digitalWrite(BUZZER_PIN, LOW);
    delay(delayOff);
  checkEndstop
  bool canMove = true;
  if (digitalRead(ENDSTOP_PIN1) == LOW && pumpingDirection > 0) canMove = false;
  else if (digitalRead(ENDSTOP_PIN2) == LOW && pumpingDirection < 0) canMove = false;
  if (canMove == false)
    lcd.clear();
    if (pumpingDirection > 0) lcd.print(F("SYRINGE IS EMPTY"));
    else if (pumpingDirection < 0) lcd.print(F("SYRINGE IS FULL"));
    beep(300);
    waitingForButton(LEFT, 1);
    return false;
  else return true;
  readFromEEPROM
  if (items[itemNo].type == LIST)
    uint8_t temp;
    EEPROM.get(4 * items[itemNo].address, temp);
    if (temp != 0 && temp + 1 != 0)
      if (items[temp].button[LEFT] == itemNo) items[itemNo].button[RIGHT] = temp;
    uint32_t temp;
    if (temp != 0 && temp + 1 != 0) items[itemNo].value = temp;
  writeToEEPROM
  uint8_t daughterItem = items[LINK2E].button[RIGHT];
  if (items[daughterItem].text == "on" || itemNo == LINK2E)
    if (items[itemNo].type == LIST) EEPROM.put(4 * items[itemNo].address, items[itemNo].button[RIGHT]);
    else EEPROM.put(4 * items[itemNo].address, items[itemNo].value);
  infuseVolume
void infuseVolume()
  int8_t pumpingDirection = 1;
  uint32_t flowrate = items[currentItem].value;
  uint32_t volume = items[items[currentItem].button[LEFT]].value;
  pumpSingly(pumpingDirection, flowrate, volume);
  infuseTime
void infuseTime()
  uint32_t pumpTime = items[items[currentItem].button[LEFT]].value;
  float tempFloat = (float)flowrate * (float)pumpTime;
  tempFloat /= 60000;
  uint32_t volume;
  if (tempFloat > 4294000000) volume = 4294000000;
  else volume = (uint32_t)tempFloat;
  refillVolume
void refillVolume()
  int8_t pumpingDirection = -1;
  refillFull
void refillFull()
  uint32_t volume = 4294000000;
  pumpSingly
  if (checkEndstop(pumpingDirection) == true)
    pump(pumpingDirection, flowrate, volume);
    beep(300);
  pumpContinuously
  int8_t pumpingDirection[2] = {1, -1};
  uint32_t flowrate[2] = {items[items[currentItem].button[LEFT]].value, items[currentItem].value};
  uint8_t i = 0;
  while (pump(pumpingDirection[i], flowrate[i], volume) != 2)
    i = 1 - i;
    beep();
  beep(300);
  pump
uint8_t pump(int8_t pumpingDirection, uint32_t flowrate, uint32_t volume)
  float tempFloat;
  ustepCounterLimit = (uint32_t)(coef * volume + 0.5);
  ustepCounterLimit *= NOFMICROSTEPS;
  float ustepsPERmin = coef * NOFMICROSTEPS * (float)flowrate;
  float multiplier;
  float ustepsPERsActual = multiplier / (float)countsPERustepActual;
  ustepsPERsActual /= 60;
  lcd.clear();
    endStopPin = ENDSTOP_PIN1;
    if (INVERTDIRECTION == true) digitalWrite(DIRECTION_PIN, LOW);
    else digitalWrite(DIRECTION_PIN, HIGH);
    lcd.print(F(" >> INFUSING >> "));
    endStopPin = ENDSTOP_PIN2;
    if (INVERTDIRECTION == true) digitalWrite(DIRECTION_PIN, HIGH);
    else digitalWrite(DIRECTION_PIN, LOW);
    lcd.print(F(" << REFILLING <<"));
  printTimeAndVolume(0, 0);
  TCNT1 = 0;
  TCCR1A = 0;
  TCCR1B |= (1 << WGM12);
    TCCR1B &= ~( 1 << CS12);
    TCCR1B |= (1 << CS11);
    TCCR1B |= (1 << CS10);
    TCCR1B |= (1 << CS12);
    TCCR1B &= ~( 1 << CS11);
  digitalWrite(ENABLE_PIN, LOW);
  digitalWrite(STEP_PIN, LOW);
  ustepCounter = 1;
  uint32_t ustepCounterActual;
  float coef2 = ((float)items[LINK2LPV].value * stepsPERmm * 1e-9) * (float)valueDivider(VOLUME) * NOFMICROSTEPS * 10;
  bool isManualStop = false;
  uint32_t pumpingVolume;
  uint16_t pumpingTime = 1;
  uint32_t nextMillis = millis() + 1000;
  OCR1A = (countsPERustepActual - 1);
  TIMSK1 |= (1 << OCIE1A);
  while ( (TIMSK1 & (1 << OCIE1A)) )
    getButtonState();
    if (buttonState == SHORTPRESS && lastButton == LEFT)
      lcd.print(F("  STOP PUMPING? "));
      lcd.print(F("(YES)       (NO)"));
        getButtonState();
            TIMSK1 &= ~( 1 << OCIE1A);
            isManualStop = true;
          else if (lastButton == RIGHT)
            if (pumpingDirection > 0) lcd.print(F(" >> INFUSING >> "));
            else lcd.print(F(" << REFILLING <<"));
    if (nextMillis <= millis())
      cli();
      ustepCounterActual = ustepCounter;
      sei();
      pumpingVolume = (uint32_t)(((float)ustepCounterActual / coef2) + 0.5);
      printTimeAndVolume(pumpingTime, pumpingVolume);
      pumpingTime++;
      nextMillis += 1000;
  pumpingVolume = (uint32_t)(((float)ustepCounter / coef2) + 0.5);
  if (isManualStop)
    lcd.print(F("  MANUAL STOP   "));
    return 2;
  if (ustepCounterLimit == ustepCounter - 1)
    lcd.print(F("    FINISHED    "));
    return 0;
    lcd.print(F("UNEXPECTED STOP "));
    return 1;
  ISR(TIMER1_COMPA_vect)
  digitalWrite(STEP_PIN, HIGH);
  if (ustepCounter == ustepCounterLimit) TIMSK1 &= ~( 1 << OCIE1A);
  if ( digitalRead(endStopPin) == LOW) TIMSK1 &= ~( 1 << OCIE1A);
  delayMicroseconds(10);
  ustepCounter++;
Thank you in advance!
What do you want to change?
Take a look at the pachterlab repository in github. It's an open source syringe pump control system that runs on Arduino with a separate serial-controlled user interface from the PC. It's fairly well documented and ready to run as-is.
Thank you so much for the suggestion cedarlake! I will make sure to take a look.
